| View Poll Results: Oil you use /recomend ? | |||
| MObil One |
47 | 83.93% |
| Castro Sync |
9 | 16.07% |
| Voters: 56. You may not vote on this poll | |||
#1 | |
Quote: "The recommended viscosity grade for this oil differs according to vehicle model. Use the recommended grade specified on the oil filler cap or in the Repair Manual or Owner’s Manual for each vehicle." |
#2 | |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
I already stated 5w-20 , not 0w-20
"5w-20 is listed for Toyota and Scion"
Sorry. When I wrote 5w-20 I was actually in agreement with you. The 0w-20 statement from the TSB was for those that might be confused into thinking that what goes for the XD engine somehow goes for the Yaris engine.
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 10-25-2008 at 03:48 PM. |
#4 | |
Beast
Guys Guys....... Its just oil =D! Lets just list the best 5 and be done with it
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
![]() ![]() Drives: yaris rs Join Date: Jul 2007
iam gonna try the greddy 5w-30 on my 4age 20v blacktop to see how it works if i like the ayri will have it too
Vroom Vroom Beep Beep
I personally run 5-30 Royal Triton (Purple). But I was just wondering is anyone using Redline Oils here? Mobil One, Ams, and Rp are three of the best you can get any of them and it would be a wise choice. Ams just makes some interesting blends some that last as long as 25,000 miles so essentially a once a year change for most.
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
You just want quiet, smooth engine reasonable economy, service life and not varnish. The Varnish will break loose at the oil changeout period and can get into small places and cause problems. Sales staff say our car has Life time "chain tensioner" and hydraulic cam phasing so this parts do not suffer varnish floating around without problem. My Family had Mazda v6 which tensioner alway is failing due to dirty oil and so to my brothers motorcycle. He had to switch to superior AECA formulation from inferior ILSAC SM specification N.A. gunk. Sorry I digress ...So, the wider the Viscosity Index the less optimal the oil will be for long life and varnish creation (cause by oxidisation of polymeric additives). So even in Ethylene gas synthesized - 0W30 worse than 10W30 and 0W20 (cause of tighter VI) better than 0w30 if engine expressly designed for the base oil weight. Yaris 1dot5 litre is not designed for 0W base oil and will have shortened service interval in this suboptimal application. Sorry Gentlemen - I try to act like dumb skirt so people will not hate me and like me but i have to throw down the gauntlet now seeing so much misinformation on this forum. Sorry to say API oil "sucks" All of it.
Last edited by TheSilkySmooth; 10-26-2008 at 10:27 AM. Reason: dark typing lessons needed |
we're using synthetic because it tames the engine noise and do many short trips. Someday may switch to a syn-blend and then to conventional oil again .
i run greddy gr3 5w 30 with some lucas oil additive and she runs smooth
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
My dad says:
Try CD oil detergent with extreme pressure-wear additives available at the local auto-parts store is very good to get API oil perform almost like AECA A3 B3? Except Viscosity will be less for economy. Will make almost to Porsche spec -S |
if using an 5w-20 , I read it's best to use one that's rated ACEA A_ and B1 or greater . The PENNZOIL Platinum 5w-20 we're using is only rated A1-02 , while the PLATINUM 5w-30 is also B1 and B5 . I believe MOBIL 1 5w-20 has a B rating , as for other manufacturers
. Would have to do some searching on the web or in the store . May go to another 5w-20 synthetic that has the B rating . The ratings are printed on the label on back of the oil bottle .
#13 | |
I would use AMSOIL or REDLINE if they were cheaper . PENNZOIL Platinum gets very good U.O.A.s ( used oil analysis ) at www.bobistheoilguy.com ( look under Used Oil Analysis - Gas ) , plus it's fairly cheap . I've picked up the PLATINUM for less than $3 a quart in the past .
#15 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris RS 4-Door LB Join Date: Oct 2008
When it will be time for my first oil change, I'll be using Mobil 1 5W-20.
Been using Mobil 1 for many, many years and never had any engine problems; besides our C55AMG and C350 uses Mobil 1 too.
#17 | |
#18 | |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
