I will update the original post later.
Mada Mada Dane...
just did the install today but im hearing a very high pitched noise. thought it was the brakes at first then i realized it was coming from something else. what did i do wrong?
No idea. Doesn't mean its directly related to your spring install.
Only thing I can think of is, on the passenger side, when you removed the strut, did you let the spindle flop out and down away from the car's wheel well? This happens sometime, but with our car, the shaft will pop out.. chances are it didnt happen, because you would notice a problem right away once you put the car in gear. |
Mada Mada Dane...
could it be that i didnt firmly tighten the nut above the bushing. my bushings are seated a little bit above the metal, they were seated firmly on the metal with the stock springs. is this normal?
Thats normal after the spring install.
..... not the noise, the top cap space. |
Mada Mada Dane...
ahhhhh what do you think i should do?
Well being none of us did the install, or are there to hear the noise, I dont know what to suggest to you.
![]() ![]() ![]() Drives: 2007 White Toyota Yaris Type S Join Date: Dec 2006
That high pitched noise, is it a metal on metal sound? do you hear it constantly? do you hear it every 1 wheel rotation? do you hear it when the cars running only, or in gear as well? Some of those answers may help.
Mada Mada Dane...
i believe it is only coming from the passenger side. its a very high pitched squeak that happens when the car is moving slow either in drive or reverse. when i get to higher speeds the sound stops. i dont know how to describe the sound. it is very very high pitched and loud sounding almost like a car with bad power steering.
See if you bent your dust cover while working that side. You may have bent it just enough to be touching the rotor slighty.
Im thinking here... im thinking... hummm... Your belts are all on the passenger side as well.. |
Mada Mada Dane...
ill have to wait until 2morrow to diagnose the problem, thanks for the info.
Mada Mada Dane...
problem fixed!!! the dust guard was rubbing against the rotor just as Chris had predicted!!!
THANK YOU SO MUCH! |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Chris is the MAN.
SPONSORED BY
#14 |
Glad to help, and glad it was something simple to fix.
#15 |
glad you got it fixed. I had that same problem on my brothers older accord. It was just so old and the metal got so flimsy that I just took it off. It was a very annoying sound, that I do remember.
#16 |
Drives: Black SandPearl Sedan Join Date: May 2007
DIY
Thanks, great instructions.
I used Sprint performance springs (claimed 1.75 inch drop) and the car actually rides better than before. I will post pic soon. |
#17 |
DIY was a great help. just a note' i found using a deep offset box end wrench worked very well for the removal of the strut tower bolt.
Thanks, B. |
#18 |
I would agree with that if only I could find a shop that sold them I have checked everywhere around here. Freakin newbie I thought that would be an easy tool to find.
| Tanabe Strut Tower Bar Install & Review [pics!] | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 04-07-2022 07:46 AM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 09:22 PM |
| Tanabe DF & Strutbar install | mcdaddy | DIY / Maintenance / Service | 18 | 05-03-2007 09:57 PM |
| TANABE DF210 SPRINGS AVAILABLE!!! | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-05-2006 12:28 AM |
| Spring Install Price | redglare45 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-30-2006 08:32 PM |
