TANABE DF210 Spring Install [pics]
*NOTE TO INSTALLERS*
This is just a GUIDE for the general way of doing the install. This is NOT a bible, you may find an easier way and much quicker way to do the entire procedure. Please add your notes and findings if it will be helpful to others. Do NOT F*CKING BITCH if you dont know right from left, loose from tight! Enjoy. Just finished the install today. Special thanks to C2AUTOSPL! for hooking me up!! After you see how easy this was, go ahead an order up a set from Jay. Total time, with finding correct sizes, removing tires, jacking up, positioning jack stands, etc., was just under 2 hours, including cleanup, and taking these pictures and notes. Your times may vary. Before doing any spring installs, I like to measure each corner, to compare later the drop given. I was at 15" at all four corners. This is always the way I measure... bottom of wheel well, in the center to center of wheel AFTER measurements were 13" all around! Starting off with the easiest part first, the REAR Springs. We will be doing both sides at the same time.. Break the lug nuts loose, then jack up the car. Position jack stands, and remove wheels. Tools Needed for rear: 9/16 deep socket; 1/2 drive 9/16 box wrench Remove the lower shock nut & bolt. Remember to do both sides before continuing. This will give the most "play" in the suspension, to drop the springs out. Once both lower shocks bolts are out, you can press down on the rear axle's, and the spring will just fall out. Comparing the Tanbe DF210's to the Stock Toyota. Be sure to re-install the top rubber coil dampener, so that the spring sits in the pocket. NOTE make sure the Tanbe DF210 logo is right-side-up!! Tanbe sends this plastic cover for the bottom of the last 4 coils. I was told its to prevent any kind of chatter, being that area is compressed so close, that the coils may rub a little. PITA to wrap it all around, but it's for the best. Rear Tanbe's installed. Tighten shock bolts, install wheels, and torque lugs to 75 Foot Pounds. Rear Complete! Moving on to the fronts. I did one side at a time up here. Tools Needed for Front: 9/16 socket; 1/2 drive 19mm deep socket; 1/2 drive 17mm box wrench 6mm allen key Hacksaw We need to remove the (2) Sway Bar end links, (2) Strut bolts, and (1) Brake bolt. Follow the bolts with sizes marked, and remove.. any order is fine. Should say LOOSEN and tighten below.. Once all is removed, the only thing holding the strut/spring assy., is the upper nut. Open the hood. Remove the entire windshield wiper plastic cowl. Stay with me, its easier then it looks! ![]() First, the wipers need to come off. Remove the cap, and with a 9/16 box wrench, remove the nuts. Next, bend wiper arm, and rock it back and forth, while pulling straight up to remove it from cowl. NOTE, I marked the wiper and threads, to make sure I re-installed it back later in the same place. Remove these (3) plastic push pins. And just set pieces out of the way. [IMG]PICTURE MISSING![/IMG] [IMG]PICTURE MISSING![/IMG] Next, pry up the rubber dust cap. Under the cap is a nut holding the top of the strut assy., to the shock tower of car. Get your 17mm box wrench and loosen the nut while HOLDING the center from spinning, with a 6mm allen key. Once loose, remove enitre assy., from car. Again, not needed, but I marked some reference points. Loosen the top hats nut a LITTLE with your 17mm and 6mm from before. Get the strut assy., in a spring compressor. Compress spring, and now you can SAFELY remove top hat, followed by the dust boot. Comparing the Tanbe and Toyota springs. Bump stop time.. You will need to shorten your bump stops, so that your not "riding the shocks" from your decrease in height. Cut against the plastic center ring, to make a nice straight cut with a hacksaw. **** NOTE **** Follow your spring makers instructions, and search or call to find out how much if any needs to be cut if installing springs/struts OTHER then what is shown in this DIY. Top hat and new, shortened bump stop. Time to re-install the strut with the new Tanbe Spring, being sure to have the bottom of spring, inside the struts stamped groove. Spring compressor not needed to install new spring. Tighten the top hat all the way (you can compress the spring assy., to see where it bottoms out). New strut ready to install.... Reverse earlier steps,....... and installed! I'm loving the new stance! Enjoy the How-Do, I hope it helps!! Last edited by vodkalush; 07-20-2007 at 01:29 PM. |
![]() ![]() ![]() ![]() Drives: 240sx, 00 Celica Join Date: Apr 2006
NIce write up. This needs to be stickied. BTW, i got your lower bar here, just need to get the right box for it.
SUPPORT YARISWORLD'S VERY FIRST SPONSOR!!
C2 AUTOMOTIVE SPECIAL 24711 Redlands Blvd., Ste. I Loma Linda, CA 92354 T: 909-796-8189 E-mail: info@c2auto.com AIM: wide180sx |
By the way C2AUTOSPL , need to clear your PM's, I need to ask you a question about some parts...
#4 | |
Is everyone able to see all the pictures above in the How-To?? Just want to be sure knowone's getting an error mesasage of sorts.
THANK YOU for the diy, it was really (really, really) helpful.
Took two of us about 3.5 hours, but we messed with the plastic and metal under the hood for a while. I had to remove the metal shroud there completely to get to the top of the front strut bolt. Just went super slow and careful, I"m always afraid I'm going to break or lose something. I would say air tools are a big plus. We used an air tool on the top front strut bolt, so we didn't need the allens wrench in there. I couldn't get a box end on there solid enough to loosen that one. Didn't need to compress the rear springs at all (the rears as SO EASY). Anyway, thanks again for the DIY, and the DF210's are a PERFECT drop for this car. Pictures forthcoming (it got dark while we were working...) woo hoo, gonna go drive it around now!! |
WERE NOT WORTHY WERE NOT WORTHY |
That Anime Guy
Nice write-up. I was installing mine earlier and the backs were a breeze. However, when doing the front I didn't need the allen wrench on the sway bar link and I also only undid the top bolt then swung it out of the way. Oh yeah, one more thing...
WEAR GLOVES When attempting to undo the top of the front strut, I couldn't get a good feel with my gloves on. So I took them off. Upon applying pressure to my wrench, my hand slipped off and slid cleanly across that sharp aluminum cover that runs across the top of the engine bay. Blood across my engine cover and exposed bone has postponed my front spring installation until further notice. Just a fair warning to others out there. <- Idiot
#9 | |
Feel better bro!
sorry....PM box cleaned.
BTW, both DF210 and NF210 now instock.
Just wonder.. do you need to use spring compressing tool for putting back the rear spring?
#12 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris S Join Date: May 2006
can see all pics fine, and nice job on the write up ;)
cant wait for my springs to come in :) oh, and maybe you should update your siggy, with the new lower yaris? :) |
#14 | |
As soon as I figure out this damn camera, ill do a nice update with my new look I have coming....
![]() Drives: meteorite liftback Join Date: Jun 2006
Great job chris, glad you did the how to instead of me. You didnt miss anything. Im also very happy with mine. Ride is just a tad stiffer but car corners a whole lot better. i didnt cut my bump stops and it hasnt bottomed out yet..knock on wood.
YARIS LIFTBACK: meteorite metallic, 5speed, debadged, 15" black rota gt-3's w/ 205/50/15's, tanabe df210's, colibri universal power window kit, glow shift 2" tach and twm shortshifter. FUTURE MOD's: power door lock kit w/ keyless entry and new audio. |
#16 | |
I called Tanbe USA just to ask and be sure, and they said to cut them as well.
#17 | |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
I second that, when you're working on your car ALWAYS WEAR GLOVES! I learned that nasty lesson the hard way when I changed the knock sensor on my I30 without removing the upper intake manifold... apparently it has this nice sharp little seam edge that's hard to see and razor sharp, I'll leave the rest to your imagination... Anyway, I used to have a nice pair of Mechanix gloves but I tore them to hell so I purchased a pair of Damascus cutproof gloves from the Galls Law Enforcement catalog at work they're meant for officers to use on patdowns, but they do really well for protecting against all the sharp little things lurking in an engine compartment as well. Oh! And looking good with the new springs, I've never used Tanabe, guess I may have to start!
| Tanabe Strut Tower Bar Install & Review [pics!] | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 04-07-2022 07:46 AM |
| Springs - Tanabe DF210 or Tein S Tech | andylai2k | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 06-10-2007 09:22 PM |
| Tanabe DF & Strutbar install | mcdaddy | DIY / Maintenance / Service | 18 | 05-03-2007 09:57 PM |
| TANABE DF210 SPRINGS AVAILABLE!!! | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-05-2006 12:28 AM |
| Spring Install Price | redglare45 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-30-2006 08:32 PM |
