Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Who said Yaris was slow?
Break'em off some.
#4 | |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#5 | |
Break'em off some.
You are sponsord by a company who produces said useless bars makes you a biased sorce of information. The fact that you would say that a Beatrush is less useless than a Tanabe is rediculous, and proves my point. Why is the strut bar useless? The front struts are mounted in RUBBER which flexes, and the strut towers themselves are part of the firewall, which is one of the strongest areas of the car. Yes, there are a couple braces that will help handling... strut braces are not one of them, on this particular car. Some of the undercar bracing is actually usefull. |
#6 | |
TRIM HUNTER
you can talk about how is does nothing all you want, problem is there's no proof to your opinions........
#7 | |
Break'em off some.
I'm saying none of the bars are really needed until you have the the front struts solidly mounted to the car. Your money is better spent on bracing the suspension arms and subframe under the car. Also, you have no proof that they do work :P |
#8 | |
Break'em off some.
^ Enjoy bracing something mounted in rubber
#10 | |
Break'em off some.
#11 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Sonjas' Brother |
aka Jack Wolfskin
Parallel Parking Pro
Race/rally cars drive in tougher terrain and higher speeds than road cars, with upgraded suspension bushings, harder and/or longer travel suspension with grippy soft-compound tires that impose more stress on the chassis.
You don't need it for the local grocery shop special stage.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#14 | |
aka Jack Wolfskin
So the tower bar is a good addition to the chassis of the Yaris, not all of the above but also for the "sporty driver". |
#15 |
Is not that the front strut bars don't do nothing... they just don't do nothing on a Yaris...
This is due to the chasis configuration of the Yaris. Even if you are driving at the track... You will have to install a full racing suspension in order to receive any benefit from a this bar on the Yaris. There are a lot of other car that can use the benefit of a front strut bar even for street use. The Yaris is not one of those. On the other side the rear sway bar does alot for the car. I have not use the other under bracing available for the car... so I can not talk about those. |
#16 | |
#17 | |
![]() ![]() Drives: 07' HB Black Join Date: Nov 2008
When life passes you by ... dowshift
| Installed the Tanabe Strut bar but had to remove my ground wire kit.. | vacantj | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-01-2007 01:56 PM |
| **NEW ITEM** Tanabe Sustec Front strut bars | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 04-27-2007 09:54 PM |
| C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 06:53 PM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | Performance Modifications | 2 | 10-07-2006 02:26 AM |
| 2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport | KenAEM | General Yaris / Vitz Discussion | 3 | 08-30-2006 09:43 PM |
