View Poll Results: Oil you use /recomend ?
MObil One 47 83.93%
Castro Sync 9 16.07%
Voters: 56. You may not vote on this poll
Old 10-20-2008, 11:48 PM   #1
gid
Drives: '08 Yaris sedan , '08 Liftback
Thumbs down not to use ...
Originally Posted by Split View Post
is running amsoil 0w-20 okay or is it too thin?
in the T.S.B. by TOYOTA says 5w-20 only , not 0w-20 . Here's the T.S.B. number , TS-EG018-06 ( the last 2 digits are the year T.S.B. was / is released ) . Got the TOYOTA service department where the '08 YARIS sedan was purchased to e-mail the T.S.B. as confirmation and saved the T.S.B. ( copied from P.C. ) in case of warranty issues with the use of the 5w-20 , says 5w-30 on oil cap and in owners manual . Best to be safe than sorry .
gid is offline   Reply With Quote
Old 10-21-2008, 12:34 AM   #2
anonymous user
rarer than JDM -1 of 1!
anonymous user's Avatar
Drives: 07yaris
I like Eneos. 5w-30. I'll be switching over all my cars from Redline soon.
Probably still use M1 in the yaris, but i'll try it out and see.
anonymous user is offline   Reply With Quote
Old 10-23-2008, 09:16 AM   #3
SilverGlow
Drives: 2007 Yaris Hatchback
If Toyota says we can use 20 weight oil, then that means 0W-20 and 5W-20. At operational temperature both these oils will protect the same. The only difference is that in very cold temperatures, the 0W will pump a bit easier, but not a lot easier then the 5W.
Same for 5W-30 and 0W-30....an engine that runs on one can run on the other.
SilverGlow is offline   Reply With Quote
Old 10-23-2008, 12:34 PM   #4
1stToyota
1stToyota's Avatar
The way I heard it explained from an expert was that the wider the viscosity the more polymers are needed and the harder it is for the molecules to stretch...something like that...under stress and heat the 5w-30 performs better.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-23-2008, 04:39 PM   #5
SilverGlow
Not according to Toyota engineeers....thiner means better circulation and faster....
Old 10-24-2008, 09:11 AM   #6
1stToyota
1stToyota's Avatar
You missed the part about the extra snake oil polymers that are required to get the wider viscosity rating and how they react under stress and heat, besides, owner's manual states 5w30 not 0w30 for the Yaris
2008 Scion xD
Old 10-24-2008, 09:47 AM   #7
SilverGlow
Your friend is not the "expert" you thought ;-)
This is because Amsoil and Mobil1 and all the others disagree with him. You see, Amsoil is the best and it makes 0W-20 and 0w-30 and tens of thousands of cars using it are not failing. In addition, UOA for those oils shows very, very low wear...so much for the "molecues cannot stretch" comment.
I would suggest we all pay a visit to BobIsTheOilGuy.com and read the forums on oil there....a lot of superstitions will die if you do...at least they did for me.
Old 10-24-2008, 12:22 PM   #8
1stToyota
1stToyota's Avatar
You can start by reading your manual and your oil cap (5w30 only) and your Toyota TSBs, and then you can finish off by stepping into the LS2 and GTO forums to inform the regs that you think SgtGeek doesn't know about motor oils and UOAs
2008 Scion xD
Old 10-24-2008, 12:59 PM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
I am sorry you did not read or understand the email I left. What is viscosity of 0w at 50C and 75 C you will see it is much less than the 5W. The engine oil may not run at 100c. You are not a chemist. An who is bob the oil guy - like bill nye the science guy I see on tv? You will not get correct information with proper scientific method on this a chat forum. I see chest beating like religious fanatics whcih is a dangerous person
TheSilkySmooth is offline   Reply With Quote
Old 10-23-2008, 12:38 PM   #10
TheSilkySmooth
Not exactly correct engine lubricant may not get to designated operational temp and viscosity of the 0W will be much less than the 5W at say 75 celcius. I am Chemist!
Make Love not Bombs! I see TSB b4 it states NO 020!
Last edited by TheSilkySmooth; 10-23-2008 at 12:41 PM. Reason: stupid today too many opium
Old 10-23-2008, 04:37 PM   #11
SilverGlow
If you're a chemist then you should know better....the 20 in 0W-20 and 5W-20 provide the same protection at full operating temperature (around 212 degrees F).
It is the first number, the 0 in 0W-20 that is thinner at cold temperatures then 5W.
And Gid yes you are correct, the Yaris engine is not TSB'd for 0w, but rather for 5W-20. However I do use 0w because the UOA reports I've seen from other Yaris owners show the same wear metals as those that used 5W-20.
Old 10-24-2008, 01:04 PM   #12
TheSilkySmooth
You are dangerouse person with a little knowledge to be bad, but not enough education to make interpolation. You may have to study some more - This Bob OIly Guy is no Koran!
Old 10-23-2008, 01:58 PM   #13
gid
read the T.S.B. closely ...
says not to . Only for CAMRY , etc.. If you want to risk it , then go for it .
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
