Old 10-21-2008, 01:42 AM   #23
maybe, but you should drive my car. The T25 turbo spools so fast and early it's amazing to drive -- I don't regret putting in the lightweight flywheel at all.
its not that it wouldn't make it as fun to drive. It basically can slow down how fast your turbo spools thus leaving you less rpms that you are actually making positive pressure. The reason being is because the heavier flywheel puts more load on the engine. More load on the engine = faster spool. Another example is the higher the gear the faster the spool. So if you are in 2nd and starts making boost at 3k rpm it will start even sooner in third because of more load on the engine. Lightened flywheels usually cater more to the n/a crowd.
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
Under $2500 Tubo Kit Update cdydjded Forced Induction Forum 16 08-26-2007 11:05 PM
another small update on turbo kit. joey1320 Forced Induction Forum 6 08-23-2007 04:51 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
