Old 05-23-2014, 09:04 AM   #1
j-san
Drives: 2010 5-door hatchback
Originally Posted by malibuguy View Post
To be honest. Keep the stock exhaust for mpg. I usually have run about 3mpg less with my exhausts. Most of the fact that I love to listen to my exhaust. Plus the stock exhaust is better matched for low rpm performance.
A typical muffler shop will only crush-bend tubing. So their 2" tubing is typically smaller in the bends then your stock midpipe. So the only thing your getting is no improvement in exhaust flow and lower quality tubing that will rust out eventually.
I suggest a rear section exhaust for some power and sound and not throwing away all your mpg.
These motors really love a full exhaust so real gains in power can be realized
Thanks much for the advice. I may just look into getting a axle-back system like the Tanabe Medalion and leave the rest stock. Maybe have the shop weld in another resonator if I find the aftermarket muffler too noisy.
j-san is offline   Reply With Quote
Old 07-09-2014, 02:03 AM   #2
dekraberd
Drives: 2013 3Dr Super white
File Type: jpg 10149401_4180781214496_247067220_n.jpg (140.9 KB, 443 views)
dekraberd is offline   Reply With Quote
Old 07-13-2014, 09:40 PM   #3
salmanghiyas
Fugitive
Drives: 2007 Yaris 4 Door Hatch
what is the basic function of these cats ?
please suggest what option from below should i go, for the maximum HP gains .. regardless of fuel economy ..
1: remove both cats and resonator and put a straight down pipe of 2" or 2.25" ( please suggest which is better 2" or 2.25" ) till the end ...
2: keep the 1st cat and remove the second cat and the resonator and put a straight down pipe till the end ...
3: keep both cats and just remove the resonator and put a straight down pipe till the end ...
4: keep both cats and resonator just put a straight down pipe after the resonator till the end ...
5: remove both cats just keep the resonator and put a straight down pipe till the end ...
salmanghiyas is offline   Reply With Quote
Old 07-13-2014, 09:44 PM   #4
mario98c
mario98c's Avatar
Remove both cats with 2" exhaust and magnaflow freeflow muffler
Old 07-13-2014, 09:56 PM   #5
salmanghiyas
Fugitive
u mean from the header neck .. i put a 2" pipe then in the middle put a resonator .. and at the end use the magnaflow muffler ?
Old 07-13-2014, 09:57 PM   #6
mario98c
mario98c's Avatar
That's correct.
Old 07-13-2014, 10:00 PM   #7
salmanghiyas
Fugitive
That's correct.
Awrite :)
and what roughly expected HP gains i would get ...
Old 07-13-2014, 10:05 PM   #8
mario98c
mario98c's Avatar
I can't tell you exact dyno numbers because I never visited a dyno after installing the exhaust but you will definitely feel the difference in acceleration. You will not regret doing it.
Old 07-13-2014, 10:11 PM   #9
salmanghiyas
Fugitive
ohkhay ...
if i use 2 resonators in the middle .. just for lowering exhaust sound .. would it effect the performance ?
Old 07-13-2014, 10:18 PM   #10
mario98c
mario98c's Avatar
ohkhay ...
I don't think so but with one resonator the car is quiet enough that it won't bother you cruising at normal speed.
Old 07-13-2014, 10:21 PM   #11
mario98c
mario98c's Avatar
Here is a video of my car with 2" exhaust, magnaflow imitation muffler(the original magnaflow should sound better) and a magnaflow 2" glasspack as a resonator. With the OEM Toyota resonator I think the car should sound better.
https://www.youtube.com/watch?v=d_tajogfKAk
Old 07-13-2014, 10:37 PM   #12
salmanghiyas
Fugitive
Very nice
Old 07-17-2014, 05:20 PM   #13
salmanghiyas
Fugitive
if i'm not mistaken ... the point you are making here is ...
the original OEM resonator in the catback which basically is the third one in line ... has 2" in and 2" out pipe width ?
Old 07-18-2014, 10:54 AM   #14
salmanghiyas
Fugitive
Yellowww ...
Old 07-20-2014, 11:54 AM   #15
salmanghiyas
Fugitive
im getting too confused now .. :S
some say go with max 2" pipes some say nah its ok even if u take 2.5" pipes .. some say keep the 1st cat .. same say remove both cats and have only one resonator in between ... :S
im surfing over the forums and internet from the last few days now ... but honestly speaking the more and more im reading stuff the more im getting confused ... :S
i did experimented one thing ... i put a 1.7" pipe ( 1.7" measurement from inside ) from the neck of the headers, removed both cats and resonator till the rear bumper and installed a topspeed muffler at the end ... the inlet of the muffler was 2.5"
Old 07-20-2014, 09:59 PM   #16
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
^ It depends what your long term hp goals are to determine which pipe diameter to go with. Here is a good read:
http://www.magnaflow.com/07techtips/faq/question10.asp
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 08-31-2014, 11:15 AM   #17
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
finally got around to getting mine back on the dyno with the current exhaust...no real difference over the old set up peak vs. peak...but after peak power was up like 7whp...
http://www.youtube.com/watch?v=yRBfjMLSNDU
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-28-2014, 12:25 AM   #18
clint
Drives: 2012 toyota yaris le
Removed stock muffler and replaced with shown baffle and tip. I think it sounds pretty good!!
clint is offline   Reply With Quote
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Why is DTM exhaust thread closed? gr8yaris Performance Modifications 4 01-13-2007 11:01 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
