Old 09-10-2010, 09:39 PM   #1
alch3miss
alch3miss's Avatar
Drives: Toyota Yaris
Originally Posted by changchewsoon View Post
that is a nice and sexy exhaust :)
Thankks got it customized for the sedan- http://www.youtube.com/watch?v=yTuYUDUCj7w is the vid for it
alch3miss is offline   Reply With Quote
Old 04-07-2009, 10:11 AM   #2
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Whoring my exhaust note in a tunnel:
http://www.youtube.com/watch?v=z5ImnarEIFw
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Old 04-07-2009, 04:21 PM   #3
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Custom work done locally here in St Pete. Stainless steel, mandrel bent, 2.0 inch piping. Magnaflow muffler.
When I get a chance I'll take some better pics and a vid clip or two.
- The Spectacle
The Spectacle is offline   Reply With Quote
Old 04-09-2009, 06:33 PM   #4
AznGouki
Metsu
Drives: NCP91 ; E36
This may be the most retarded question but does the 5 door and the 3 door have the same exhaust? Like if I bought a exhaust labeled 3 door, will it fit my 5? Some times I feel so dumb haha
AznGouki is offline   Reply With Quote
Old 04-09-2009, 10:24 PM   #5
Mouse
Drives: 2007 MX5
2" is small...I personally would've gone with 2.25" for NA application. It will help with low to mid range power.
Mouse is offline   Reply With Quote
Old 04-09-2009, 10:26 PM   #6
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Wrong. Probably make it worst. 2" is perfect for N/A. If he went with bigger piping, he'd be LOSING power in the low to mid range.
Old 04-10-2009, 08:52 AM   #7
The Spectacle
Drives: 08 BSP LB
You honestly think .25 inch is going to make a difference on a 1.5L 100hp car????
Well, it will be louder and slower. So maybe just not the difference you're looking for. I certainly wasn't.
Old 04-09-2009, 10:38 PM   #8
Mouse
Drives: 2007 MX5
so why not go with 1.5"...2.25" is the perfect size for NA applications. Anything bigger is for more peak horse power.
Old 04-09-2009, 10:47 PM   #9
Mouse
Drives: 2007 MX5
Read.....
http://www.miata.net/garage/KnowYourCar/S4_Back.html
Old 04-10-2009, 10:33 AM   #10
Mouse
Drives: 2007 MX5
Well, if the stock exhaust diameter is 1.75" then the extra .5" would make a difference.
Did you see a difference in going from 1.75" to 2.00"?
That's only a .25" difference.
Old 04-10-2009, 10:10 PM   #11
jdinrc
jdinrc's Avatar
Drives: 2009 Yaris Blazing Blue 3dr
There is a significant difference in only 0.25".
2" pipe is 3.14in/sq area
2.25" pipe is 3.97in/sq area
That's a 26.4% increase in flow capacity going from 2" to 2.25". Sounds like 26% would make some sort of difference to me.
jdinrc is offline   Reply With Quote
Old 04-10-2009, 11:19 PM   #12
megan axleback
Old 04-24-2009, 07:45 PM   #13
treppen
Drives: BRUTAL
Axel back
I ride like I got a horse stable under my hood
treppen is offline   Reply With Quote
Old 04-24-2009, 09:15 PM   #14
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
Good Results with Automatic Transmission? I have an Automatic Sedan and want to know.
monchito18 is offline   Reply With Quote
Old 04-27-2009, 07:20 PM   #15
Jerkratt
Jerkratt's Avatar
finally got a chance to put the CEL box that garm sells into the mid pipe. it works, I've scanned with scan gauge and cleared prior (cel temp. off) then installed. has been fine ever since
"It hurts more when its wet"
Old 04-27-2009, 11:42 PM   #16
megan axleback w/ muffler painted flat black
Old 05-12-2009, 01:36 PM   #17
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
my set up
mine..
vids in here..: http://www.yarisworld.com/forums/sho...ight=magnaflow
Old 05-20-2009, 05:52 AM   #18
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
I have Posted my Pics here to and I found for everyday use 2" is better to zip along with tafic etc. I have also tested this theory already, and I speak my Yari is getting Dyno Tuned branches\Headers being Build for it, what I will do is try and post the Dyno Charts for the diffrent Pipes and header combo's, I am in SA though but it could be used as a guide for everyone else out there, btw it is the T1 and its being done by Viper Exhaust, I Cant wait....
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Why is DTM exhaust thread closed? gr8yaris Performance Modifications 4 01-13-2007 11:01 AM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
