![]() ![]() Drives: 09 Yaris hatch, 09 Z51 'Vette Join Date: Oct 2008
I'd love to see you prove that empirically.
Peak HP occurs at 6,000 RPM. Redline occurs at 6,500 RPM. You'll want to shift at or near red-line for peak performance, even though engine horsepower falls off after 6,000 RPM. Why? Because doing so will put the engine closer to its horsepower peak in the next gear (immediately after the up-shift) while ensuring peak obtainable drive-wheel torque at all vehicle speeds. Precise shift points would be determined in the fashion discussed in this link: http://www.allpar.com/eek/hp-vs-torque.html Generally speaking, shifting at red-line is a good "rule of thumb" for maximizing acceleration. That tends to be especially true for higher revving, small displacement DOHC engines (e.g. Yaris engine). I've been told that the Yaris's owner's manual recommends the following shift points for maximum acceleration: 1 to 2: 31 MPH 2 to 3: 59 MPH 3 to 4: 86 MPH Assuming that's true, I suspect that each of those shift points corresponds to engine red-line in the Yaris models equipped with tachs. |
#2 | |
Peak power (106 HP @ the flywheel) occurs at 6,000 RPM - just like Toyota says it does. Peak power will be less when measured on a chassis dyno, though the RPM at which it occurs will be identical. That says little about determining shift points for optimal acceleration, though, as explained here: http://www.allpar.com/eek/hp-vs-torque.html Generally speaking, one wants to shift at engine red-line (ABOVE PEAK HP RPM) in order to maximize acceleration. That's particularly true with "peaky," small displacement, DOHC engines (e.g. Yaris 1.5 liter). |
#3 | |
TRIM HUNTER
#4 | |
If it's off, indicated speed will differ from actual speed. |
#5 | |
![]() It's nice to have peak HP so close to redline, as it makes your point that much easier to work with. And, for most people (as well as the common point of view), shifting at redline would be best. Last edited by justjesus; 10-22-2008 at 09:04 PM. |
