Old 10-22-2008, 06:46 PM   #21
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
if you like i could scan the page relating to this from the actual manual. let me know.
as for max power best way would be to do a dyno run and see the RPMs at which power peaks, Garm i believe has acces to a dyno
Please scan that page of the manual if you don't mind.
Peak power (106 HP @ the flywheel) occurs at 6,000 RPM - just like Toyota says it does. Peak power will be less when measured on a chassis dyno, though the RPM at which it occurs will be identical.
That says little about determining shift points for optimal acceleration, though, as explained here:
http://www.allpar.com/eek/hp-vs-torque.html
Generally speaking, one wants to shift at engine red-line (ABOVE PEAK HP RPM) in order to maximize acceleration. That's particularly true with "peaky," small displacement, DOHC engines (e.g. Yaris 1.5 liter).
09TRD is offline   Reply With Quote
