Old 10-22-2008, 03:27 PM   #1
grampi
Drives: Corolla
I don't understand why cars equipped with manual transmissions don't come with a tach (even base models). The exact purpopse of having a tach is to let you know when to shift, which is something you need with a manual tranny.
grampi is offline   Reply With Quote
Old 10-22-2008, 03:43 PM   #2
ddongbap
Because you simply don't need a tach to drive. Auto or manual.
Old 10-22-2008, 05:24 PM   #3
grampi
Drives: Corolla
I disagree. I think if you have a manual tranny you need a tach.
Old 10-22-2008, 05:27 PM   #4
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
DON'T NEED NO STINKiN TACH, ive gotten used to listening to my motor......
Old 10-22-2008, 05:50 PM   #5
justjesus
justjesus's Avatar
Drives: 2008 Liftback
LOL - my friend is trying to convince me to get a tach. I tells him i don't needs it, so whatever! you don't NEED a tach when driving a manual. If it was truly NEEDED, Toyota would have installed it.
As for PK's (?) numbers being different from the owner's manual... well, that was just HIS preference. We all shift at different speeds. Also, i believe the original queston (sort of, as it was more like TWO parts) was...
I'd like to know how fast I can go in each gear in order to achieve maximum acceleration.
You wont achieve max accel from redlining these motors.
Old 10-22-2008, 05:53 PM   #6
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
You can use the speedometer as an indicator for red-line in each gear, which is the point of this thread.
I put little marks on the face of the speedometer on my 1997 Tacoma 2wd. I used the stick on "pin striping" tape that I bought for a couple of bucks somewhere. I marked it per the "maximum shift points" in the owner's manual. It worked fine.
09TRD is offline   Reply With Quote
Old 10-22-2008, 05:56 PM   #7
justjesus
justjesus's Avatar
not a bad idea, the pin striping.
Oh, also. I believe the manual calls for 1,000 MILES break in distance. The sad part, they mention, is you can't just take a long drive, or keep it at certain speed for "extended periods" or something like that. So my idea of a Vegas trip to break it in was thrown out the window. booooo. LOL
Old 10-22-2008, 06:01 PM   #8
09TRD
I'd love to see you prove that empirically.
Peak HP occurs at 6,000 RPM. Redline occurs at 6,500 RPM.
You'll want to shift at or near red-line for peak performance, even though engine horsepower falls off after 6,000 RPM. Why? Because doing so will put the engine closer to its horsepower peak in the next gear (immediately after the up-shift) while ensuring peak obtainable drive-wheel torque at all vehicle speeds.
Precise shift points would be determined in the fashion discussed in this link:
http://www.allpar.com/eek/hp-vs-torque.html
Generally speaking, shifting at red-line is a good "rule of thumb" for maximizing acceleration. That tends to be especially true for higher revving, small displacement DOHC engines (e.g. Yaris engine).
I've been told that the Yaris's owner's manual recommends the following shift points for maximum acceleration:
1 to 2: 31 MPH
2 to 3: 59 MPH
3 to 4: 86 MPH
Assuming that's true, I suspect that each of those shift points corresponds to engine red-line in the Yaris models equipped with tachs.
Old 10-22-2008, 07:46 PM   #9
09TRD
if you like i could scan the page relating to this from the actual manual. let me know.
as for max power best way would be to do a dyno run and see the RPMs at which power peaks, Garm i believe has acces to a dyno
Please scan that page of the manual if you don't mind.
Peak power (106 HP @ the flywheel) occurs at 6,000 RPM - just like Toyota says it does. Peak power will be less when measured on a chassis dyno, though the RPM at which it occurs will be identical.
That says little about determining shift points for optimal acceleration, though, as explained here:
Generally speaking, one wants to shift at engine red-line (ABOVE PEAK HP RPM) in order to maximize acceleration. That's particularly true with "peaky," small displacement, DOHC engines (e.g. Yaris 1.5 liter).
Old 10-22-2008, 09:36 PM   #10
justjesus
justjesus's Avatar
1 to 2: 31 MPH
2 to 3: 59 MPH
3 to 4: 86 MPH
And I'd love to prove it as well. If i had easier access to a track, I'd do it. Would you settle for a measured distance (1/4 mile) vs time (stopwatch)?
It's nice to have peak HP so close to redline, as it makes your point that much easier to work with. And, for most people (as well as the common point of view), shifting at redline would be best.
Old 10-22-2008, 05:46 PM   #11
PaidTimeOff
OMGWTFKITTYKATMEWMEWMEW
Drives: 2008 Yaris S
Well, you clearly don't NEED a tach, as people have been driving manual transmission vehicles without tachs for decades. Hell, even the manual 1997 Ford Escort I drive for work doesn't have a tach and it's still going strong after more than a decade of use. You may WANT a tach so you can see your revs, but it's definitely not required to effectively drive a manual transmission car.
PaidTimeOff is offline   Reply With Quote
Old 10-22-2008, 05:51 PM   #12
grampi
Drives: Corolla
You're not doing much to help me make my argument. I know you don't NEED a tach to drive a manual, but isn't having one nice? It isn't asking that much for Toyota to quit being so damn cheap and just include one in the base Yaris. They're already selling these cars for a much higher price than they should be. It isn't like Toyota isn't going to make a profit on these cars if the included a tach.
Old 10-22-2008, 05:54 PM   #13
09TRD
It's "nice" to have leather seats, 300 HP, AWD, a power moon-roof, etc.
Right?
But I think the base Yaris's equipment level is FINE for its price level.
Get one of the higher trim levels if you want a tach.
Or buy a tach and install it.
Old 10-22-2008, 05:59 PM   #14
PaidTimeOff
If to you it's too much money for what you get, then don't buy it. Toyota cut a few bucks off their production costs by not including the tach in lower models. The lack of a tachometer also motivates buyers to upgrade to the higher level lb if they really want it. Sounds like good business to me.
Old 10-23-2008, 09:43 AM   #15
grampi
Drives: Corolla
You shouldn't have to buy the most expensive trim level just to get a tach. At the very least, it should be available as a stand alone option.
Old 10-23-2008, 09:50 AM   #16
ddongbap
I've been through this argument with many others. I'll go over it with you.
Toyota didn't include a tach, to provide a super cheap ass Yaris. Want a tach? Get a S model. Still don't like it? Get a Fit.
Earlier you had stated that you NEED a tach for a manual transmission, but now you're saying,
=grampi]I know you don't NEED a tach to drive a manual,
Its bad enough Toyota isn't making much on these cars anyways. Toyota obviously doesn't care about the Yaris, as they do the other models. There's nearly no Yaris commercials anymore.
Old 10-23-2008, 06:04 PM   #17
grampi
Drives: Corolla
I'm not buying that Toyota isn't making much money on the Yaris. It can't cost Toyota much more than $8K to put a Yaris on the Dealer's lot, and yet Toyota can't keep them on the lots at $12-$17K. They don't advetise them because they don't have to. You also can't get any buyer's incentives on them, again because they sell themselves.
Old 10-23-2008, 09:47 AM   #18
ddongbap
You're doing it right now, aren't you? There are tons of other Yaris manual owners who're not running any tachs, yet are still able to drive, AMIRITE?
