Old 10-22-2008, 06:46 PM   #1
09TRD
Drives: 09 Yaris hatch, 09 Z51 'Vette
if you like i could scan the page relating to this from the actual manual. let me know.
as for max power best way would be to do a dyno run and see the RPMs at which power peaks, Garm i believe has acces to a dyno
Please scan that page of the manual if you don't mind.
Peak power (106 HP @ the flywheel) occurs at 6,000 RPM - just like Toyota says it does. Peak power will be less when measured on a chassis dyno, though the RPM at which it occurs will be identical.
That says little about determining shift points for optimal acceleration, though, as explained here:
http://www.allpar.com/eek/hp-vs-torque.html
Generally speaking, one wants to shift at engine red-line (ABOVE PEAK HP RPM) in order to maximize acceleration. That's particularly true with "peaky," small displacement, DOHC engines (e.g. Yaris 1.5 liter).
09TRD is offline   Reply With Quote
Old 10-22-2008, 07:02 PM   #2
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Originally Posted by 09TRD View Post
Peak power (106 HP @ the flywheel) occurs at 6,000 RPM - just like Toyota says it does. That says little about determining shift points for optimal acceleration, though, as explained here:
i have no tach and hence rely on engine sound so i can attest to to the claim about peak power. i say this cause when i shift at redline i notice a slight bog in power but when i shift JUST before im spinning 18inch tires in second gear and third doesn't have that lag you get around 60 mph........
Old 10-22-2008, 07:35 PM   #3
09TRD
How does the rolling diameter of 18" set-up compare with the OEM set-up?
If it's off, indicated speed will differ from actual speed.
