| View Poll Results: Oil you use /recomend ? | |||
| MObil One |
47 | 83.93% |
| Castro Sync |
9 | 16.07% |
| Voters: 56. You may not vote on this poll | |||
#37 |
rarer than JDM -1 of 1!
I like Eneos. 5w-30. I'll be switching over all my cars from Redline soon.
Probably still use M1 in the yaris, but i'll try it out and see. |
#38 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
An entire fleet of Toyota engineers, quality testers, risk analysts and lawyers wholeheartedly disagree with you as their recommendation is 5k miles. Anything more often is a waste of money and resources.
Back on topic: I run Mobil1 5W-20 EP synthetic and a K&N Gold oil filter for the 15k mile drain interval.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#39 | |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
#40 |
That would be sludge. Bad I tell you, very bad!
#41 |
So I use aimsol for no slug? You buy this from a friend, Does it cost too much?
#42 | |
#43 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Any SM-rated 5w-30. Currently on Motomaster Formula 1 (blended by Shell for Canadian Tire IIRC) dino for rated five-to-six-month intervals. I don't clock enough mileage to change it out beforehand.
#44 |
The poison in your poison
Drives: 2008 Black Liftback MT Join Date: Oct 2008
Are there any national auto parts stores that sell oil like Amsoil or Royal Purple or do I have to order the stuff online? I am coming up on my first oil change and want to make the switch but haven't seen any of this good oil that you guys are using in any local stores.
#45 |
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
go here to find local supplier for AMSOIL , www.amsoil.com/dealerlocatorresults/ .
#46 |
![]() ![]() ![]() Drives: 08 toyota yaris LB Join Date: Oct 2008
amsoil 0-30 wouldnt really hurt my motor right? or should i switch it right away to 5-30. i have 500 miles on 0-30 and my car has 20k mi
#47 |
HISTORY REPEATED 11/04/08
Royal Purple 5-20.
#48 |
My brother says that like bay-4 motorsports has good oil for motorcycle and this should be better for car then even the S&M. I dont go to bike stores they bother me too much and I have to leave
#49 |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Why does the poll show only two choices?
Do this: Pick the "worse" and cheapest synthetic oil on the market that has the current API ratings (SM). Use that oil and your car will last no less long as if you had used AMSOIL or Mobil1 or any of the other brands. People say this oil is great or that oil is great but how do they know? They like the purple color? They think paying a premium means longer lasting car? How many of these people actually send a used oil sample to a testing lab like BlackStone for thorough analysis? Yet the ones that don't have their used oil analyzed will push their brand of choice hard. Lots of hearsay, lots of parroting the claims of others. Me? I use the cheapest on-sale full synthetic and don't have the dillusion that one is much better the the other. I've seen the UOA's (used oil analysis) at BobIsTheOilGuy dot com and I'm convinced that as long as (1) the oil has the latest ratings (2) is synthetic, (3) correct viscosity and (4) mated with a decent filter, your car will last 300,000+ miles regardless of brand. Please guys lets not turn motor oil into a religion filled with passion and fervor ;-) |
#50 | |
If Toyota says we can use 20 weight oil, then that means 0W-20 and 5W-20. At operational temperature both these oils will protect the same. The only difference is that in very cold temperatures, the 0W will pump a bit easier, but not a lot easier then the 5W. Same for 5W-30 and 0W-30....an engine that runs on one can run on the other. |
#51 | |
#52 | |
Make Love not Bombs! I see TSB b4 it states NO 020! Last edited by TheSilkySmooth; 10-23-2008 at 12:41 PM. Reason: stupid today too many opium |
#53 | |
read the T.S.B. closely ...
#54 | |
It is the first number, the 0 in 0W-20 that is thinner at cold temperatures then 5W. And Gid yes you are correct, the Yaris engine is not TSB'd for 0w, but rather for 5W-20. However I do use 0w because the UOA reports I've seen from other Yaris owners show the same wear metals as those that used 5W-20. |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Engine oil ddi not come out | hans_fh | DIY / Maintenance / Service | 18 | 01-23-2009 11:30 PM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
