Old 10-23-2008, 11:45 PM   #1
gid
3.5 quarts for fill ...
Originally Posted by DESIGNZIT View Post
How many quarts does it hold and do you mean 10W30 Mobil 1 ?
, carefully top off if needed . The 3 and 1/2 quarts I use for both '08 YARIS bring it to or slightly below the FULL mark . Don't forget oil is still in valve train area and in the oil pan , therefore at least 1/2 quart or so may still exist . You could drain the oil and then measure the amount for comparison .
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Which brand of oil and filter do you use? Yaris_Fan DIY / Maintenance / Service 31 02-15-2007 08:40 PM
