View Poll Results: Oil you use /recomend ?
MObil One 47 83.93%
Castro Sync 9 16.07%
Voters: 56. You may not vote on this poll
Old 10-24-2008, 11:30 PM   #1
SilverGlow
Drives: 2007 Yaris Hatchback
Originally Posted by 1stToyota View Post
...you claim that 5w20 is "TSB'd" for the Yaris (you're thinking Scion XD?), and you wrote that you use 0w (wouldn't matter if a 20 or 30 followed because my Yaris owner's states 5w30 only)...so, to follow your rule number (3) start using the "correct viscosity" if you're still expecting to see that 300k miles on your motor.
You're confused, but that's okay. I do follow my rules. The TSB shows 20 weight for our engines, and I use 20 weight, and the UOA's show less wear then if I used 30 weight. Sure, the filler cap shows 30 weight, BUT the TSB which came out later says otherwise. I'm sticking with the TSB. As to 0W weight, I use that because at full operational temperature 0w-20 and 5w-20 protect exactly the same; hence the 20 part of those grades. The 0w on cold mornings flows to the upper parts of thje engine faster and gets to more parts of the internals faster.
SilverGlow is offline   Reply With Quote
Old 10-25-2008, 01:07 PM   #2
1stToyota
1stToyota's Avatar
It's okay that you're too dense to read...the TSB *notes* the 0w-20 is for the 2AZ-FE engine, not the Yaris 1NZ-FE engine...you did a XD motor swap in your Yaris?!
And if you live in CA why worry about those "cold mornings flows"...besides, in that TSB that you're swearing by, take note of the note @ the top of the page:
"The recommended viscosity grade for this oil differs according to vehicle model. Use the recommended grade specified on the oil filler cap or in the Repair Manual or Owner’s Manual for each vehicle."
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
