Old 10-25-2008, 01:26 PM   #1
richardholdener
Drives: 2008 Yaris hatch
As indicated elsewhere in this post, the retail pricing is $699. No pics are available since all we have is the performance prototype which does not represent the production intake. What we need at this point is to generate an official list. We need to have 10 yaris owners step up to purchase the intake so they can go into production. There will be NO deposit money required up front, just your word in print that you will be purchasing the intake when the production pieces are ready. Prior to any payment and shipping the production intakes, I will be happy to have Garm (or other member) come out for an official dyno test to illustrate the gains. For this intake to be produced, we need to have 10 buyers. If we get 20 buyers, we can talk about a group buy which would knock off $50 per manifold.
richardholdener is offline   Reply With Quote
Old 10-25-2008, 03:23 PM   #2
cee_dub2003
Drives: Scion xb
I would just like to throw my 2 cents into this. I take my hat off to the making of this intake manifold. I really don't see committing to a high dollar item without seeing more info on this intake manifold. Everyone has to realize you are committing "with your word and in print" to purchase a item that hasn't even been seen yet. I wouldn't commit to buy any performance item without seeing pictures. whats wrong with posting prototype pictures? Its prototype right? I think everyone here would like to see pictures, and have more info on what they are committing to this.
Any A/F readings taken?
cee_dub2003 is offline   Reply With Quote
Old 10-25-2008, 06:28 PM   #3
richardholdener
Air fuel is the same as stock intake since this motor has a mass air meter.
Old 10-26-2008, 09:39 PM   #4
cee_dub2003
Drives: Scion xb
That is really hard to understand! For one the MAF only calibrates air volume and AIT temp. adding more air into each cylinder would cause the car to run lean, and ping, causing the knock sensor to draw back timing to compensate for the lean in tunr loosing HP.
I have seen a intake manifold for a TC do this. I would really like to see how you have done this when the Toyotas MAF is a very learing piece of equipment.
Old 10-27-2008, 12:53 AM   #5
richardholdener
Hopefully this will help you and others understand why your comments are somewhat inaccurate. The mass air meter is not a learning device, it is a simple measurement device that measures mass flow (temp, volume and infered density). The learning portion of the equation comes from the ECU (interpretation of signals from various sensors including MAF). Using a hot wire, voltage is applied to keep the wire at a given temperature. The greater the airflow (or lower the temperature of said air), the greater the voltage required to maintain a constant element temperature. This change in voltage (or frequency on some MAF applications) is correlated to airflow based on the relationship between ID of the meter assembly and what is refered to as the sample tube (flow orifice to hot wire element). The change in airflow through the system (that happens at different engine speeds and/or loads) is compensated for by the MAF. The same thing happens with changes in airflow from something like an intake upgrade. Problems can arise when you run out of effective meter range (we call this topping out the meter-meaning we reach the voltage ceiling near 5.0V). This can happen with major power gains like those achieved with a blower or turbo. We rescale the meter and combine it with larger injectors for these applications, but for something simple like an intake upgrade-there is no need for this. In reality, altering the mass air meter (by orientation, entry or alteration of ratio between flow orifice and metering orifice) will have much more of a change in the air/fuel ratio than adding the intake manifold. This knowledge on the workings of a mass air meter plus the actual data that came from the hundreds of direct back-to-back dyno tests run indicate that the air/fuel is not effected by the change in intake manifold on the Yaris. I make it a point never to bring speculation to a data fight.
Old 10-27-2008, 01:20 PM   #6
cee_dub2003
Drives: Scion xb
Thank you for clarifying that better for me. Sorry for the somewhat information information.
Old 10-25-2008, 08:13 PM   #7
ddongbap
People on this forums buy F/I kits that produce similar power and spend tons more.
Just because you don't believe the words of this master, doesn't make it false.
He probably doesn't post a picture, because like just about everyone else in this world, if he posts the prototype picture, everyone'll expect that. Or have some kind of misguided opinion of the product. When the final one arrives, and isn't what people expected, even though that isn't what was even promised, people'll complain. Its what happens.
And because you think that you need pictures, doesn't mean the rest of us do. Don't speak for the rest of us.
Old 10-25-2008, 08:38 PM   #8
kou
Drives: 08 lb
this is the versa manifold.
Old 10-25-2008, 03:37 PM   #9
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im sure there are 20 people right now who want one one. if we had 40 people whats the discount then???
Old 10-25-2008, 06:26 PM   #10
richardholdener
Since we don't even have 10 people willing to put their name on a list as of yet-I think it is a little premature to talk about group buys for 40. Also, the photo issue has already been addressed-only a prototype exists and it does not represent the production piece. Here is a photo of the production Nissan Versa intake-the yaris intake will feature a head flange, runners and a common plenum with a throttle body mount,but it will look nothin glike this one nor will it look like the prototype used for testing. There will be no photos of the prototype intake-only if and when the production piece is ready to display (much earlier than the full production run if we get the requistite number of yaris owner to indicate they intend to purchase if and only if we provide the following things: 1. an intake that bolts on a provides the power gains illustrated by the power graph, accepts the stock throtle body and associated lines and fittings and runs with no CELs at a price of $699). Since I am asking for no money up front, only an indication to purchase if these requirements are met. Please let me know if there is sufficient interest or if we should move on to a different application..
Old 10-25-2008, 06:27 PM   #11
richardholdener
Nissan Versa intake photo too large to upload-can I e-mail it to someone to manipulate?
Old 10-25-2008, 10:21 PM   #12
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
If the prototype doesn't look like the functional production piece, would it still work the same and put out similar dyno numbers?
Showing us a Nissan Versa manifold doesn't do much for me; it has less in common to an actual production Yaris manifold than a prototype Yaris manifold.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
WeSellCarParts.com // Weapon R Yaris Dragon Air Intake WeSellCarParts WeSellCarParts 19 12-27-2008 09:31 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
