Old 10-26-2008, 11:07 AM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Why not let the oil filter capure the particles - it is there for this reason. If you go around a tight corner at high rpm you could make a tornado in your oil pan and this debris would get swept off and start circulating - our timing chain can pump this stuff up top - another problem chain vs timing belt. Is you chain noisy whirrring noise?? this is a lot of debris.
TheSilkySmooth is offline   Reply With Quote
Old 10-26-2008, 11:13 AM   #2
TheSilkySmooth
I did not type this my Papa did. Go AWAY!
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Magnetic Oil Drain Plug PetersRedYaris DIY / Maintenance / Service 13 11-16-2010 06:41 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
Who Makes Magnetic Transmission Plug? blacksan DIY / Maintenance / Service 5 05-22-2007 10:15 AM
Magnetic Drain Plug Source? blacksan DIY / Maintenance / Service 9 05-11-2007 08:01 AM
