![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
Nitto Mid-Pipe Check Engine Light fix
so i have the mid pipe and i remember before the hack there was a "help!" part number for the o2 censor was wondering if anyone still had that part number as i wanna go there and get one
"It hurts more when its wet" |
TRIM HUNTER
i believe its HELP part #4240 at any parts store.
![]() ![]() Drives: 2007 Sedan S Join Date: Oct 2008
anti seize
![]() Drives: Black NCP91R Join Date: Oct 2008
wow.
wow is right i never even knew you could do it that way
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
Lol. Trick-my-o2-sensor.com !
Did you have any problems with the mating of the mid-pipe? Someone out there had a source for a custom extension for the sensor. Can't remember who though. Been really considering getting this so I can add my header but waiting till the bugs are finally gone.
What some people have done is have the muffler shop weld a tight 90deg bung on the pipe which will then allow you to stack the two extenders without the sensor coming in contact with anything below. The wire is just barely long enough.
so....then 1 wont work?
I used to have 1700 posts
E-mail this guy wayne92slc@yahoo.com he makes a piece that will move the o2 sensor far enough away from the gasses to the point where it doesnt set a CEL. he has them in stock $38 shipped. i will be ordering mine next week
Thanks Whooppee....saving that for later
![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
To any who have the nitto, when you removed your stock mid, did you have a problem "unscrewing" the o2 sensor? I tried to remove it to wrap the midpipe with thermal wrap and it sun a couple of times then just seemed to wedge where it was. Anyone else have this happen?
To those with a custom midpipe...if i bring my car to have a custom mid made, should i assume that there will be no CEL issues or should i inform them of the issue? Also around how much did it run you guys? Thanks.
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
jerkratt, need to use both of those defoulers...been using the defouler now for 1 week after i installed a new header, NO CEL!
kuro, u might just want to wait until the ecu relearns! |
#15 | |
Who said Yaris was slow?
Is just the sensor doing it's job.The function of the sensor behind the primary cat is to monitor the adecuate functionality of the cat converter. When you remove / delete the cat converter the sensor obviously will sence a cat failure and throw a CEL. The Nitto midpipe is a catless unit threfore it will trigger the CEL. When you say you are going for a custom mide pipe are you planning to go catless also? If so you will have a CEL and you will need one of the already mentioned CEL fixes. If you keep your cat or install a new cat to the custom midpipe you should be alright and will not need any fix. Just my recomendation: Keep the cat... the gains for going catless should be minimal on this engine. Just ask your shop to make your midpipe from the cat back... |
^ didn't even notice that u only used one of them....yeah the other one might help!
#17 | |
#18 | |
TRIM HUNTER
besides that i do believe EVERYONE experiences a CEL with the defouler eventually.on the other hand the soldering of the wires looked to be a good deal though........
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Check engine light on | kcty | DIY / Maintenance / Service | 19 | 03-10-2012 08:54 PM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| Check Engine Light Question | falkor_99 | General Yaris / Vitz Discussion | 11 | 07-22-2007 05:15 PM |
