For like 30 min. I talked to a tech at Toyota Glendora this morning and hes said that one of both rotors sticking is pretty common, and that there are two M8 threaded holes in the rotor that I can use to force the rotor off of the spindle. I can't wait to try it!
Drives: 2009 Toyota Yaris Base Join Date: Dec 2014
Has anyone determined that M8 bolts will in FACT fit the threaded rotor holes?
I have a couple of bolts that I use, but I don't have access to them at the moment to check. Most Japanese cars use M8x1.25, but for some reason I want to say that the Yaris uses fine pitch (M8x1.0). Just buy yourself two of each to be safe.
| DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads | ChinoCharles | DIY / Maintenance / Service | 40 | 10-13-2017 05:23 PM |
| BIG(GER)TM BRAKE KIT | Vanderkitten | Performance Modifications | 23 | 01-04-2009 07:16 PM |
| Removing front bumper | fat45s | DIY / Maintenance / Service | 1 | 01-31-2007 06:25 AM |
| removing front plate | Lowfront | Cosmetic Modifications (Exterior/Interior) | 19 | 08-25-2006 09:59 PM |
| Removing third brake light | lightyearsgirl | DIY / Maintenance / Service | 8 | 08-06-2006 11:26 AM |
