#1 | |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
besides that i do believe EVERYONE experiences a CEL with the defouler eventually.on the other hand the soldering of the wires looked to be a good deal though........
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
![]() ![]() Drives: Yaris Liftback Join Date: Oct 2008
I wonder what the soldering of wires does to the fuel mappping, if anything.
As stated above, the second O2 sensor does not affect fuel mapping in any way, it is only in place to confirm to the ECU that the catalytic convertor is in place and functioning properly. Even with this sensor completely removed your performance and fuel mileage will not change.
#4 | |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
I like the anti foulers better than the soldering method. The mechanical method can never fail. |
#5 | |
TRIM HUNTER
REALLY, please elighten us as to who accomplished this.
Break'em off some.
How hard is it to understand.. 1 or 2 antifoulers move the o2 sensor far enough out of the exhaust stream to not throw a Cat Inefficiency CEL when you are running catless.
I've used this method on hundreds of cars.. Subarus, Evos, Toyotas, Mustangs etc. I did this on my WRX about 6 years ago. I didnt know about antifoulers then, but this was cleaner.
#7 | |
TRIM HUNTER
#8 | |
Break'em off some.
Your ECU is not scouring the internet looking for proof that you have screwed with it.. and throwing CELs when you wake up in the morning. What you fail to realize is how an ECU works. ECUs operate on voltage signals from sensors. When voltage is out of an acceptable range on a given sensor for a certain amount of time, an CEL is given (or worse, it depends on the sensor). By wiring in a resistor to give the ECU a different voltage reading, or by mounting the o2 sensor out of the stream of exhaust you change the voltage sent to the ECU. If the "new" signal is within accepted limits, a CEL is never thrown. These limits don't change, and the ECU does no "learning" for the rear o2 sensor. If you don't throw a CEL in the first couple days, or couple hundred miles, you will probably never see one for cat ineffiecicy. These types of CELS are not thrown right away because cats are less effective when cold, and the ECU is programmed to account for that. Again, no "learning" involved. |
#9 | |
TRIM HUNTER
good explanation but i never said the wiring method was bad. just the fouler
#10 | |
I used to have 1700 posts
TRIM HUNTER
if you have no problems GREAT but ive seen some on here who drove for 2 weeks with nothing and then BLAM...........
TRIM HUNTER
NO it just happens all of a sudden......
#13 | |
Break'em off some.
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Check engine light on | kcty | DIY / Maintenance / Service | 19 | 03-10-2012 08:54 PM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| Check Engine Light Question | falkor_99 | General Yaris / Vitz Discussion | 11 | 07-22-2007 05:15 PM |
