#1 | |
Break'em off some.
Im assuming the car is understeering on power off the corner? If it is you need to stiffen the rear compression to keep more weight on the front wheels, also you can stiffen the front rebound a bit, and this will also help with body roll. Adjust those two until the car starts to turn better. You will want to make most of your adjustment to rear compression and fine tune it with front rebound. |
#2 | |
Parallel Parking Pro
TS will have to decide whether he wants comfort or performance and live with the compromise.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#3 | |
Break'em off some.
To be honest, the ride quality should improve a bit (or at least not get any worse) when he turns up the damping to match his spring rate. At full soft, he may be over sprung. |
| Critique my upcoming setup. | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-23-2008 08:40 PM |
| C-ONE handling products for Yaris... | trdyaris1 | New YARIS Purchase Forum | 2 | 05-23-2007 02:02 AM |
| Suspension Setup Question | Ran Kizama | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 27 | 04-28-2007 02:05 PM |
| Handling impressions from owners | whoguy | General Yaris / Vitz Discussion | 15 | 10-20-2006 07:38 PM |
| sedan handling sucks | punch | Performance Modifications | 16 | 09-29-2006 09:26 AM |
