Old 10-29-2008, 11:38 AM   #12
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Originally Posted by largeorangefont View Post
It really depends how serious you want to get here. 2 degrees for negative camber in the front, and no toe, or just the slightest bit of toe in should do it for alignment.
Im assuming the car is understeering on power off the corner? If it is you need to stiffen the rear compression to keep more weight on the front wheels, also you can stiffen the front rebound a bit, and this will also help with body roll. Adjust those two until the car starts to turn better. You will want to make most of your adjustment to rear compression and fine tune it with front rebound.
Given that he seems to be complaining about a stiff rear end, I think in this case stiffening the rear to bring weight distribution forward would work for the uphill climb but doesn't improve the daily ride comfort.
TS will have to decide whether he wants comfort or performance and live with the compromise.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Critique my upcoming setup. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 0 10-23-2008 08:40 PM
C-ONE handling products for Yaris... trdyaris1 New YARIS Purchase Forum 2 05-23-2007 02:02 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
Handling impressions from owners whoguy General Yaris / Vitz Discussion 15 10-20-2006 07:38 PM
sedan handling sucks punch Performance Modifications 16 09-29-2006 09:26 AM
