Old 10-28-2008, 08:02 AM   #8
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
Actually understeer or oversteer is a function of which end of the car has more grip.But a car can understeer or oversteer on the same setup, it just depends whether it is accelerating or braking. That is down to weight shift.
People run stiff suspension to fight weight shift in corners and improve handling response.Otherwise you want to run the car as soft as you can get away with, in order to obtain the most amount of grip. Soft suspension has more grip than hard suspension assuming there is no distortion of the contact patch as a result of body roll.
There are several things you can play with, geometry, ride height, sag, tire pressures, rebound and/or compression rates. They all conspire to create the car's handling characteristics. Even if a factory stock car, adding or substracting air from the front or rear tires can have a marked effect on the car's handling characteristics.
- Negative camber helps the car grip better in the bends. While it is possible to adjust your rear camber by means of shims, I shall assume that you are only talking about the more-common front end camber adjustment. More negative front camber gives more grip to the front end in the bends as compared to the rear. Generally, a car pointed uphill would be more understeery than when it is pointed downhill, that is my understanding of weight distribution.
- Suspension set too hard, the wheels do not follow the dips and bumps in the ground well. This translates into loss of traction. If the ground is extremely smooth (eg. prepared race circuit) you might be able to get away with it. Racing suspension are tunable, because it is necessary to optimize the spring and damping rates for each particular track condition. For road cars, a softer setting that suits a wider range of conditions would be better.
Leong's NCP91 Toyota Yaris E
Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38
Stebel horns, Philips Silvervision turn indicator bulbs
TTE Lowering Springs, Camber bolts
TRD Blue brake pads
Fujitsubo Super Wagolis axleback exhaust
DC Sports header
cleong is offline   Reply With Quote
Critique my upcoming setup. IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 0 10-23-2008 08:40 PM
C-ONE handling products for Yaris... trdyaris1 New YARIS Purchase Forum 2 05-23-2007 02:02 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
Handling impressions from owners whoguy General Yaris / Vitz Discussion 15 10-20-2006 07:38 PM
sedan handling sucks punch Performance Modifications 16 09-29-2006 09:26 AM
