View Poll Results: Oil you use /recomend ?
MObil One 47 83.93%
Castro Sync 9 16.07%
Voters: 56. You may not vote on this poll
Old 10-29-2008, 12:42 PM   #1
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Originally Posted by gid View Post
I would use AMSOIL or REDLINE if they were cheaper . PENNZOIL Platinum gets very good U.O.A.s ( used oil analysis ) at www.bobistheoilguy.com , plus it's fairly cheap . I've picked up the PLATINUM for less than $3 a quart in the past .
HI Mr. GID: Do you get the high mileage with your platinum oil too? Is the Power good? How do you drive hard or easy? This may be a good deal
TheSilkySmooth is offline   Reply With Quote
Old 10-29-2008, 12:48 PM   #2
Benggolf2
Benggolf2's Avatar
When it will be time for my first oil change, I'll be using Mobil 1 5W-20.
Been using Mobil 1 for many, many years and never had any engine problems; besides our C55AMG and C350 uses Mobil 1 too.
Old 10-29-2008, 01:13 PM   #3
gid
Drives: '08 Yaris sedan , '08 Liftback
with the PLATINUM 5w-30 the power is good , been averaging close to 39 miles per gallon since last NOVEMBER , and it tames the engine noise . Using REDLINE MT-90 true synthetic gear oil as well for the '08 5 speed liftback . This car was used for delivery route once a week for about 8 months as well , so quite extreme driving . One time the car got 42 m.p.g. while doing the route , other times 40 or little less ( some of that included 4 studded tires ). The route was 100+ miles , 4 hours long , around 400 stops , many steep hills , and 2 people . There's usually 2 of us in the car since the purchase . The '08 automatic sedan has the PLATINUM 5w-20 and got 40.03 miles per gallon on a test drive after 4 studded tires were put on ( see post under FUEL ECONOMY FORUM ) . That car has overall average of 39 miles per gallon as well , right on par with the stick shift . We'll have to wait and see how the colder weather affects it .
gid is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Engine oil ddi not come out hans_fh DIY / Maintenance / Service 18 01-23-2009 11:30 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
