Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
How hard is it to understand.. 1 or 2 antifoulers move the o2 sensor far enough out of the exhaust stream to not throw a Cat Inefficiency CEL when you are running catless.
I've used this method on hundreds of cars.. Subarus, Evos, Toyotas, Mustangs etc. I did this on my WRX about 6 years ago. I didnt know about antifoulers then, but this was cleaner.
#2 | |
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
#3 | |
Break'em off some.
Your ECU is not scouring the internet looking for proof that you have screwed with it.. and throwing CELs when you wake up in the morning. What you fail to realize is how an ECU works. ECUs operate on voltage signals from sensors. When voltage is out of an acceptable range on a given sensor for a certain amount of time, an CEL is given (or worse, it depends on the sensor). By wiring in a resistor to give the ECU a different voltage reading, or by mounting the o2 sensor out of the stream of exhaust you change the voltage sent to the ECU. If the "new" signal is within accepted limits, a CEL is never thrown. These limits don't change, and the ECU does no "learning" for the rear o2 sensor. If you don't throw a CEL in the first couple days, or couple hundred miles, you will probably never see one for cat ineffiecicy. These types of CELS are not thrown right away because cats are less effective when cold, and the ECU is programmed to account for that. Again, no "learning" involved. |
#4 | |
TRIM HUNTER
good explanation but i never said the wiring method was bad. just the fouler
Break'em off some.
The foulers do the same thing but mechanically. You are reducing the amount of exhaust gasses the sensor is exposed to, and skewing the reading. Some cars need 2 of them to keep from throwing CELs, one drilled for the sensor, and one undrilled.
#6 | |
TRIM HUNTER
ok so you finally got in your head what ive been saying except for the fact that even with the double fouler method that CEL still comes on. NO, who on here is running this setup and has no light.......
super duper M*******TOR
Drives: 2007 jahPANIS egg(Sarao Phil) Join Date: Oct 2008
no CEL!
Break'em off some.
#9 | |
I used to have 1700 posts
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Check engine light on | kcty | DIY / Maintenance / Service | 19 | 03-10-2012 08:54 PM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 01:43 PM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| Check Engine Light Question | falkor_99 | General Yaris / Vitz Discussion | 11 | 07-22-2007 05:15 PM |
