Old 10-31-2008, 07:54 PM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
maybe a 5mm led try measure the holes and go measure a 5mm led to see or a 10mm led at like radio shack if its one of those oznium.com sells them pre wired
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-31-2008, 08:49 PM   #2
IsLNdbOi
IsLNdbOi's Avatar
Been googling screw sizes for license plates and it looks like American cars use 1/4" screws and I've been seeing 6mm and 6.3mm for Japanese (Toyota, Nissan, etc.) cars.
Old 11-01-2008, 10:20 PM   #3
Meteorite_Marty
Guys, the 48 LED board will NOT fit into the trunk area!!! Check my orignal post.
There is only 2cm x 4.5 cm worth of space. I cut a cardboard template of each light board before I ordered, based on the specs supplied form VLEDS. The 30 LED board is rectangular and will fit the trunk light housing. The 48LED is square and impossible to fit. The 48 LED board fits perfectly into the cabin light area, which has excess space to spare with a 7.5cm x 4.5 cm housing (approximately).
Old 11-01-2008, 10:49 PM   #4
Meteorite_Marty
Some late night photography! Sorry for my crappy night pics... no tripod. Picures can only show so much. These lights really brighten up the cabin. I can actually see the floor and back seat area, with no shadows or ugly yellow. The white color is consistent with amongst all VLED lights, for all cabin, map, and trunk lighting.
Interior map (2 x 11 LED 194 bulbs) and cabin (1 x 48 LED board)...
Old 11-01-2008, 10:50 PM   #5
Meteorite_Marty
More pics of the trunk using the 30 LED board. No more ugly, dim, warm white/yellow incandescent bulbs!!!
Old 11-03-2008, 02:22 AM   #6
DerKaiZeRs
-YaRiS OwNeR-
DerKaiZeRs's Avatar
Drives: YRS Sedan
Hi meteorite.. so 48 LED board will FIT into the DOME light right?
coz I just bought LED from ebay and it doesn't fit into the DOME light because it is too Thick....
and what do u mean by 2 x 11 LED 194 bulbs that you put into the interior map.
Can you show me the type of that LED??
DerKaiZeRs is offline   Reply With Quote
Old 11-03-2008, 09:09 AM   #7
k3nn4
Drives: Yaris Sedan
"I hope you do read this post carefully.."
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
This is the one!
k3nn4 is offline   Reply With Quote
Old 11-05-2008, 06:36 PM   #8
Meteorite_Marty
Yes, the 48 LED board fits into the DOME light (that is the one that goes off and on with the door opening). Naturally the board doesn't fit into the bracket where the festoon was. You have to run the dummy-festoon and wiring to the power clips, then mount the LED board somewhere in the plastic housing of the dome light.
Old 11-10-2008, 12:17 AM   #9
k3nn4
Drives: Yaris Sedan
I've received my LEDs from V-LEDs just then and installed! I've to say "This is Awesome! Extremely Bright and just fit except for Number Plate (11 LED 194 bulbs) :( A little bit long but still managed to install into it.
Old 11-02-2008, 07:14 AM   #10
k3nn4
Drives: Yaris Sedan
Nice effect! I placed my order at v-leds :) thanks for the picture
Old 11-05-2008, 06:43 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
All the coupons I've found (including the above NISSANCLUB one) are 10% off.
Old 11-12-2008, 10:18 PM   #12
Meteorite_Marty
the only think thats a turn off about the Vleds is the shipping, guys/gals try Ileds same products or almost and the shipping is more reasonable
That's like saying almost pregnant. :)
Vleds are awesome, and the shipping is quite fair, especially when you use the discount coupon.
Old 03-29-2009, 11:24 PM   #13
njiteb
Mario Mushrooms & Totoro!
Drives: Absolutely Red Yaris LB 2007
sorry to bring up an old topic, but i can't seem to get the cover off of my hatch light or the map lights..only got the dome one done for now.. anyone can help?
njiteb is offline   Reply With Quote
Old 03-30-2009, 12:20 AM   #14
Meteorite_Marty
For both, you will need a very small flat head screw driver.
The map light covers can be removed by placing the screw driver in the center gap, in between the pair. Then press towards the outside, away from the centre. Each of the covers are on 2 small pop-off hinges, located at each corner nearest the center. It might help if you move the screw driver towards one of the hinges, while keeping it in the center gap, then apply the pressure towards the outside, as mentioned.
The trunk light is held on by a plastic clip, under the grey plastic of the interior. Itcan be popped off by inserting the screw driver on the front edge of the light housing and lifting upward and out.
Old 03-30-2009, 01:45 AM   #15
njiteb
thanks! i'm also wondering if the screwdriver will scratch the grey plastic if i apply too much pressure. i actually tried to do that to my trunk light with the screwdriver i use for my computer screws, but was afraid i might break the clips or scratch the interior.
Old 03-30-2009, 05:51 PM   #16
Meteorite_Marty
If you're careful, it shouldn't scratch. Good idea about the credit card, but I am not sure how much leverage you can get from that. Plus, I am not sure the credit card is a Genuine Toyota Approved technique (inside joke!).
Old 03-30-2009, 03:22 AM   #17
IsLNdbOi
IsLNdbOi's Avatar
Try using a credit card to pry it out.
Old 03-30-2009, 06:02 PM   #18
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
my thoughts on this.
http://www.yarisworld.com/forums/showthread.php?t=15663
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How do you replace the factory fog light bulb DjT DIY / Maintenance / Service 6 10-25-2008 07:24 AM
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... riceboy Items for Sale by private party 453 07-14-2007 08:30 AM
Cheap LEDs Interior and Exterior jamal1984 Cosmetic Modifications (Exterior/Interior) 10 04-11-2007 11:08 AM
Yaris S Replace Fog Light Bulbs jamal1984 DIY / Maintenance / Service 1 01-13-2007 08:16 PM
