Old 10-29-2008, 10:58 PM   #1
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
Originally Posted by largeorangefont View Post
How hard is it to understand.. 1 or 2 antifoulers move the o2 sensor far enough out of the exhaust stream to not throw a Cat Inefficiency CEL when you are running catless.
I've used this method on hundreds of cars.. Subarus, Evos, Toyotas, Mustangs etc.
I did this on my WRX about 6 years ago. I didnt know about antifoulers then, but this was cleaner.
YEAH, thats cool and all but what you fail to realize is the LEARNING ecu that will eventually catch on and prove my point......
Old 10-30-2008, 11:55 AM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Rockland,
Your ECU is not scouring the internet looking for proof that you have screwed with it.. and throwing CELs when you wake up in the morning.
What you fail to realize is how an ECU works. ECUs operate on voltage signals from sensors. When voltage is out of an acceptable range on a given sensor for a certain amount of time, an CEL is given (or worse, it depends on the sensor).
By wiring in a resistor to give the ECU a different voltage reading, or by mounting the o2 sensor out of the stream of exhaust you change the voltage sent to the ECU. If the "new" signal is within accepted limits, a CEL is never thrown. These limits don't change, and the ECU does no "learning" for the rear o2 sensor.
If you don't throw a CEL in the first couple days, or couple hundred miles, you will probably never see one for cat ineffiecicy. These types of CELS are not thrown right away because cats are less effective when cold, and the ECU is programmed to account for that. Again, no "learning" involved.
Old 10-30-2008, 03:16 PM   #3
ROCKLAND TOYOTA
TRIM HUNTER
Rockland,
good explanation but i never said the wiring method was bad. just the fouler
Old 10-30-2008, 04:31 PM   #4
largeorangefont
Break'em off some.
The foulers do the same thing but mechanically. You are reducing the amount of exhaust gasses the sensor is exposed to, and skewing the reading. Some cars need 2 of them to keep from throwing CELs, one drilled for the sensor, and one undrilled.
Old 10-30-2008, 07:39 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ok so you finally got in your head what ive been saying except for the fact that even with the double fouler method that CEL still comes on. NO, who on here is running this setup and has no light.......
Old 10-30-2008, 08:42 PM   #6
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
no CEL!
Old 10-31-2008, 12:04 PM   #7
ROCKLAND TOYOTA
TRIM HUNTER
Originally Posted by Malaya1221 View Post
no CEL!
yeah cause you just put this on a week ago or so correct???
Old 10-31-2008, 09:56 AM   #8
largeorangefont
Break'em off some.
See post #48.
Old 10-31-2008, 12:05 PM   #9
ROCKLAND TOYOTA
TRIM HUNTER
See post #48.
see post 51
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 08:54 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
