Old 10-31-2008, 03:02 PM   #1
nemelek
DWEED
nemelek's Avatar
Originally Posted by b_hickman11 View Post
No it doesnt.....The way you mentioned is for rear wheel drive vehicles, which are usually trucks. The way I mentioned is what is recommended by the tire manual for front wheel drive vehicles like the Yaris.
Page 252 of my 2008 Yaris Hatchback Owners Manual has a rotation diagram of what I stated previously. Maybe the sedan's manual shows a different rotation pattern. On my old 88 Toyota 4X4 and 04 Dodge Ram 4X4 the rotation suggests crossing the left and right sides.
Old 10-31-2008, 09:57 PM   #2
b_hickman11
Drives: 08 Sedan
Toyota makes cars and Bridgestone makes tires. Dont follow Toyota's manual. You need to look at your tire manual. It says "Tire Maintenance, Safety and Warranty Manual" on the front of it. Refer to page 6. I am attaching a copy of this page but it might not work......
b_hickman11 is offline   Reply With Quote
Old 11-01-2008, 08:00 AM   #3
nemelek
DWEED
nemelek's Avatar
Thanks for proving my point!
On page 6 of the Bridgestone Tire Safety and Warranty Manual it clearly states "For maximum mileage, rotate your tires according to the vehicle manufacture's recommendations (consult your vehicle owner's manual)."
I'll use the Bridgestone's recommendation to use the Yaris Owner's Manual guidelines on tire rotation. This will save me time and effort by only having to jack up one side of the car at a time.
In the long run, it probably doesn't matter which rotation pattern is used. What matters is that it is done in a timely and consistant manor.
Old 11-01-2008, 11:20 PM   #4
b_hickman11
Drives: 08 Sedan
The Toyota owners manual also says that you should not over inflate your tires by their recommendations which is 32 psi. It states that over inflating will cause poor handling, excessive wear, etc. So you go by your Tire company for psi but you go by Toyota for rotation guidelines?? You think that Toyota's psi ratings are a joke and that the tire company's rotation guidelines are a joke?? Sounds like you don't know who to follow or maybe you are believing every thing you see on the net?
Old 11-03-2008, 05:01 PM   #5
nemelek
DWEED
nemelek's Avatar
I have never seen a psi recommendation by a tire company. Anybody who has put any thought behind this would understand why. The tire company doesn't know what kind of car the tires are going on. FWD, RWD, AWD, 4WD?? They don't know the weight or the weight distribution of the vehicle. Therefore they leave the proper inflation up to the manufacture. For example on my 08 Yaris running stock Bridgestone 185 60R 15 the small print on the tire says "Follow owners manual or tire plagard in vehicle -- Inflate to recommended pressure -- Never exceed 40 psi." So the tire company has suggested that the user follow both the rotation and inflation guidelines set by the manufacture. I trust Toyota engineering and do things the way the owners manual states. The real injustice to the "net" is that people without reading the owners manual are able to state personal opinions as fact.
On a side note. I don't care what psi people are using. However, I have been involved in 2 personl injury lawsuits involving lawyers and insurance companies. I wouldn't put anything past either of them. If you are driving with over inflated tires and posting your psi on the internet and get into an accident caused by a blow out, the insurance company or lawyer will find a way to use that information against you.
Old 11-04-2008, 12:17 PM   #6
SilverGlow
Drives: 2007 Yaris Hatchback
I have never seen a psi recommendation by a tire company. Anybody who has put any thought behind this would understand why. The tire company doesn't know what kind of car the tires are going on. FWD, RWD, AWD, 4WD?? They don't know the weight or the weight distribution of the vehicle. Therefore they leave the proper inflation up to the manufacture. For example on my 08 Yaris running stock Bridgestone 185 60R 14 the small print on the tire says "Follow owners manual or tire plagard in vehicle -- Inflate to recommended pressure -- Never exceed 40 psi." So the tire company has suggested that the user follow both the rotation and inflation guidelines set by the manufacture. I trust Toyota engineering and do things the way the owners manual states. The real injustice to the "net" is that people without reading the owners manual are able to state personal opinions as fact.
ALL tire companies do IN FACT recommand a PSI setting for their tires. Surely you're not that stu---....nevermind.
Guess where Toyota gets the recommanded PSI from?
The. Tire. Company.
In addition, it does not matter if the car is 4x4 or what it weighs because the amount of air needed to put a tire to a particular PSI differs according to the weight of the vehicle. So our Yars, for example needs less air in the tires for 35PSI then if the car weighted say 500 lbs more. In other words, all you have to do is add enough air to bring the PSI to the proper level...
SilverGlow is offline   Reply With Quote
Old 11-04-2008, 08:46 PM   #7
nemelek
DWEED
nemelek's Avatar
The. Tire. Company.
I will bet you $100 that you can't find any proof where Bridgestone recommended to Toyota to put 32 PSI in their 185 60R 15 tires for the Yaris.
There is probably an industry guidelines for tire type and sizes. The amount of load on a tire and the corresponding the PSI are in those guidelines. It's Toyota's responsibility to pick a correct tire and recommend the proper PSI.
The weight of a vehicle does matter. If the Yaris was a 1,000 pounds heavier or lighter their might be a different tire or PSI recommendation. On the chart below for the Dodge Ram you will note that the front tires for a light load with the diesel require 10 to 15 PSI more than the V-8. Why? Because the diesel weighs a lot more. Notice when the truck goes from light load to heavy load the PSI for the rear tires go from 40 to 70 or 80. Why? Because as the weight increases there is an additional need to increase the PSI. There are some idiots that would put 120 PSI in the rears. Do you really think that "The.Tire.Company." made this chart for Dodge? More likely Dodge engineers figured the load for the tires in different situations and used the tire guidelines from the manufactures put together this chart.
Old 11-04-2008, 08:50 PM   #8
nemelek
DWEED
nemelek's Avatar
recommanded
I may be stu--- but at least I can spell recommended.
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Yaris Crashed! elsteverino889 General Yaris / Vitz Discussion 13 11-06-2006 02:59 AM
