Old 11-01-2008, 11:20 PM   #10
b_hickman11
Drives: 08 Sedan
Originally Posted by nemelek View Post
Thanks for proving my point!
On page 6 of the Bridgestone Tire Safety and Warranty Manual it clearly states "For maximum mileage, rotate your tires according to the vehicle manufacture's recommendations (consult your vehicle owner's manual)."
I'll use the Bridgestone's recommendation to use the Yaris Owner's Manual guidelines on tire rotation. This will save me time and effort by only having to jack up one side of the car at a time.
In the long run, it probably doesn't matter which rotation pattern is used. What matters is that it is done in a timely and consistant manor.
The Toyota owners manual also says that you should not over inflate your tires by their recommendations which is 32 psi. It states that over inflating will cause poor handling, excessive wear, etc. So you go by your Tire company for psi but you go by Toyota for rotation guidelines?? You think that Toyota's psi ratings are a joke and that the tire company's rotation guidelines are a joke?? Sounds like you don't know who to follow or maybe you are believing every thing you see on the net?
b_hickman11 is offline   Reply With Quote
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Yaris Crashed! elsteverino889 General Yaris / Vitz Discussion 13 11-06-2006 02:59 AM
