Old 11-01-2008, 12:10 AM   #1
dallas
Drives: Yaris Hatch /Landrover D2
With previous dyno runs with bigger intake manifolds and throttle bodys without more displaement, more cam, or forced induction a higher flowing intake will offer very little gain and may loose h.p /torque until very high rpm.
What calculations are you using for runner diameter and length.
dallas is offline   Reply With Quote
Old 11-01-2008, 01:43 PM   #2
richardholdener
Drives: 2008 Yaris hatch
Is this question directed at me? The statement that a higher flowing intake will yield very little gain and may loose hp until high rpm is inaccurate. Intake manifolds are not simple flow devices-they are tuned to produce power at specific engine speeds based on the other variables you mentioned (displacement, cam timing etc...) It does not take a bigger or higher flowing intake to make more power, it takes the right design elements. The calculations are extremely complicated for more reasons than I can go into in such a short space. We ran over 100 different combinations before deciding on this one illustrated by the dyno curve provided. Intake design is more than just welding together a plenum, runners and flange.
richardholdener is offline   Reply With Quote
Old 11-01-2008, 01:44 PM   #3
richardholdener
PS-The tuning effect works the same on NA and FI applications.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
WeSellCarParts.com // Weapon R Yaris Dragon Air Intake WeSellCarParts WeSellCarParts 19 12-27-2008 09:31 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
