#1 | |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
On a side note. I don't care what psi people are using. However, I have been involved in 2 personl injury lawsuits involving lawyers and insurance companies. I wouldn't put anything past either of them. If you are driving with over inflated tires and posting your psi on the internet and get into an accident caused by a blow out, the insurance company or lawyer will find a way to use that information against you.
Making a decision without following it with an action is still a fantasy. Last edited by nemelek; 11-09-2008 at 05:50 PM. |
#2 | |
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
Guess where Toyota gets the recommanded PSI from? The. Tire. Company. In addition, it does not matter if the car is 4x4 or what it weighs because the amount of air needed to put a tire to a particular PSI differs according to the weight of the vehicle. So our Yars, for example needs less air in the tires for 35PSI then if the car weighted say 500 lbs more. In other words, all you have to do is add enough air to bring the PSI to the proper level... |
#3 | |
DWEED
There is probably an industry guidelines for tire type and sizes. The amount of load on a tire and the corresponding the PSI are in those guidelines. It's Toyota's responsibility to pick a correct tire and recommend the proper PSI. The weight of a vehicle does matter. If the Yaris was a 1,000 pounds heavier or lighter their might be a different tire or PSI recommendation. On the chart below for the Dodge Ram you will note that the front tires for a light load with the diesel require 10 to 15 PSI more than the V-8. Why? Because the diesel weighs a lot more. Notice when the truck goes from light load to heavy load the PSI for the rear tires go from 40 to 70 or 80. Why? Because as the weight increases there is an additional need to increase the PSI. There are some idiots that would put 120 PSI in the rears. Do you really think that "The.Tire.Company." made this chart for Dodge? More likely Dodge engineers figured the load for the tires in different situations and used the tire guidelines from the manufactures put together this chart.
Making a decision without following it with an action is still a fantasy. Last edited by nemelek; 11-09-2008 at 05:52 PM. |
#4 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
#5 | |
DWEED
The last post was for a 2004 3/4 ton 4X4 which weighs 7,000 pounds. I think the 1 ton is 500 pounds heavier.
Making a decision without following it with an action is still a fantasy. |
DWEED
I may be stu--- but at least I can spell recommended.
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
| Yaris Crashed! | elsteverino889 | General Yaris / Vitz Discussion | 13 | 11-06-2006 02:59 AM |
