Old 11-04-2008, 10:24 AM   #11
Well, if I may share my 2 cents, I've had a lot of time to think about this conundrum...
As much as we want, we cannot expect any sensible improvement of low to mid-range torque with just bolt-on NA mods. You must realize that a 1.5L engine can only do so much. Sure, you could get higher compression pistons, a stroker kit and maybe some new cams, but AFAIK those also really come into their own at high RPMs.
The reason is, sadly, there is no replacement for displacement. You cannot expect the torque of a bigger engine, it's just not gonna happen. You won't see Pee-Wee Herman bench pressing 300lb, you won't see a 1NZ with V8 torque...
So, one must realize this intake manifold is not some magical end-all solution to more power. If the best results are a pretty sizeable increase of torque from 2500RPM onward, then I think it is correct for the manufacturer to maximize on this.
This means that yes, on the street, if you drive in a calm and "normal" manner, you'd never really see an advantage. This intake manifold will really come into its own where it is designed to, at high RPMs, so it will be of most use to those who really race their cars, be it on a track or autocross.
It was said in a previous post, or one that was lost with the hack, but this manifold could be compared to a "bolt-on VTEC", as it gives the engine the ability to keep revving far better than stock. And, as with VTEC, the love-hate relationship is that you have to keep the engine at high RPMs to get good power output from it.
If you really want more low-end torque, the most effective solution is more displacement. This is where forced induction comes in, as it can be considered "virtual displacement" (think about this... normal atmospheric pressure is what, 14psi? a turbo running at 7psi is thus forcing in 50% more of atmospheric pressure, thus giving your engine characteristics of one that is 50% larger, or 2.2L. Of course, this is a very rough generalization, kinda like giving steroids to Pee-Wee!). This is why superchargers excel in this area, they start shoving in more air as soon as the engine is moving, same thing with small, responsive turbos that may not create massive boost, but can start to supply it quite early.
There you have it... If you seriously want more low end torque, go for a small turbo or supercharger. Of course, it's $3000 vs $700, I think that's also an important reason why many are wishing for a "low RPM" version of the intake.
I'm in no way an engine expert, so feel free to pick apart what I've just written
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
EBay: Yaris Intake Manifold ChinoCharles Performance Modifications 21 10-22-2008 04:35 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
