Old 11-04-2008, 02:18 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I have to seriously contest the flashlight battery theory. A couple of problems: there should be soot/melting directly above the flashlight, and the tray itself should have melted substantially; the flashlight should show significant damage, yet appears basically unscathed. Also, that flashlight appears to be one of the aluminum screw-together type, which would be at least semi-waterproof. It would need to burst somewhere at its seams or at the lens, which also doesn't appear to have happened. Finally, alkaline batteries are safe at temperatures of 180 degrees Farenheit plus, and it would be tough to produce that even here in Dallas in August.
Anecdotally, I have kept a mini maglight and a 6V lantern in my car/trunk for most of the past 20 years in Texas, including in a black CRV, and never had the slightest hint of heat damage/leakage/combustion. Also, my brother used a maglight in Afghanistan and Iraq, where temperatures routinely exceeded 120 degrees farenheit AIR temp. No idea what that translates to inside a dark-colored, armored and sealed HumVee sitting in the sun all day, but no flashlights exploded.
One other thing: I don;t know about Aussie Toyotas, but US Yarii have the 12V outlet wired to the ignition, so no power would flow to the GPS when the key was out.
Old 11-04-2008, 02:29 PM   #2
darthbauer
Not really here...
darthbauer's Avatar
Did you have a car charger for your mobile phone in there?
I remember one time with my old Accord that it got so hot it sparked. I unplugged it and never used it in the car again.
Liberate Tutemet Ex Infernis.
Old 11-04-2008, 03:09 PM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
That is the case in Australia as well.
rob323 is offline   Reply With Quote
Old 11-06-2008, 12:02 AM   #4
auxmike
auxmike's Avatar
Did the flashlight use Lithium batteries?
I have a small Streamlight Scorpion in my glovebox right now. I left it on while it was standing upright on it's lens on a table, the lens started to melt! Those lights run HOT. After seeing this, I'm removing my Scorp from the car in the morning.....
Old 11-06-2008, 04:25 AM   #5
purpleminx
Drives: '08 5DR Silver Yaris HB
No, and it was nothing to do with the flashlight.
Originally Posted by k r a y z e e . j o j o View Post
Did you leave your phone hooked up to it? Ask because the back of my phone gets kinda hot when it's been charging for an hour or so. Just a possibility...
No, and it didn't have power going through the cable anyway, considering I was not in the car, so the keys weren't either ;)
Very close right now to finding the cause. Will definitely post their answers.
purpleminx is offline   Reply With Quote
Old 11-06-2008, 06:31 PM   #6
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Hmm, that's a stumper...
Old 11-09-2008, 11:39 AM   #7
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I'd check to see that your Scorp is legit. IIRC, they have a glass lense.
firemachine69 is offline   Reply With Quote
Old 11-09-2008, 12:57 PM   #8
auxmike
auxmike's Avatar
About the Streamlight;
The lens appears to be a clear plastic of some sort. I bought it from Texas Tactical Supply, it's the real deal. Nice torch, but it eats through Li batts. like crazy....
After reading this thread, I went right to the glovebox and removed it from the YARIS.
I'll be using an LED MiniMag from now on.
Old 12-10-2008, 03:37 PM   #9
rob323
Purpleminx, any updates on whether the cause of the fire was pinpointed yet?
Old 12-11-2008, 11:26 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
http://www.sjdiscounttools.com/cosll7742.html
I am a mechanic and keep this on my belt every day. Lasts about 2 weeks before i needs to be charged. Keep in mind it has daily use sometimes for a hour at a time. And have had it for a year so far. Battery hasnt really got weak yet. And its insanely bright. Its dropped on the floor multiple times and got run over by a car too =).
Old 12-12-2008, 12:46 AM   #11
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I want an update purpleminx
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
Trade upgraded radio and dash for base radio and dash??? Yarisguy13 Items for Sale by private party 4 09-17-2007 06:32 PM
dash problems...help needed foggy08 DIY / Maintenance / Service 1 01-25-2007 08:04 PM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 11:51 AM
