Old 11-06-2008, 10:05 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by Spades View Post
well, very rarely will popping a amp on improve sound quality, cause its still amplifying the source....its only as good as the signal it recives.
this is even more true when you are going "cheap" and dont want to spend money.
what I would suggest, either buy a aftermarket deck, or buy a cheap amplified subwoofer tube and a line converter if it doesnt have one.
either get a deck that can drive the speakers, or get a small powered subwoofer if you want bass. almost everything else will be wasted money or not as good of a solution. expect to spend around 150 bucks or to be disappointed.
I dont want to end up putting in a subwoofer. Actually the subs in my door panels are pretty decent when the volume is low. Sounds almost as good as my acura with 2 12s . Except when the volume is turned up there is a obviouse difference.
I plan to put 6x9s in the back maybe 2 ways. To help balance things out.
I think i may end up putting ina double din deck for the front. And have to buy a new bezel since i have intergrated cd player.
Anyone happen to know th epart number or where i can buy that silver bezel that is on the base model yaris that has the non intergrated cd player
And also what are some good high power low cost double din decks.
I am willing to spend up to 300. minus install
Any money i save can go to get higher quality rear speakers
Old 11-07-2008, 02:09 PM   #2
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
why are you going to save up for high quality rear speakers when you sit in the front? you should put more money in the front since thats your soundstage.
staypuft is offline   Reply With Quote
Replacing stock deck - photo tutorial gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-06-2012 01:04 PM
Connect mono amp. + subwoofer to stock HU? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 23 10-28-2008 10:01 PM
Installing aftermarket componenet speakers and an amp in a LB grampi In Car Entertainment + Electronics (audio / video / alarm) 2 07-06-2007 07:49 AM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
Custom Sub Enclosure (inc sub, power cap, amp) wado Items for Sale by private party 3 09-18-2006 11:53 AM
