#1 | |
Who said Yaris was slow?
In theory a 4-1 will provide a better gain and higher rpm while a 4-2-1 will provide better gains at the mid range. The problem is that by design the Yaris header is so short that I doubt there is much difference between any of the current model available. So I would tell you to choose the one that fits your budget! If you want the ultimate set up and still keep it legal for emission testing I will tell you to get a high flow cat Only one or at least remove the secondary cat leave the primary cat. You already have a bolt on muffler so you just need the mid pipe. If you can get mandrel bent tubing go for 2" pipe if you can't get it, then go for 2.25" pipe. If you want it civil, snap a round mufller/resonator in the middle in place of the OE resonator and ou are good to go! And the header will make some difference as long as you work out the rest of the muffler. Not much gain by mating a header with a stock exhaust. |
#2 | |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#3 | |
1NZ-FE
i'm asking cuz i wanna do a mod almost like this |
#4 | |
Both models come with 2 cat converters. First one just after the exhaust manifold and the other one a few inches after. The car has 2 sensors on the exhaust the first one and the most important is in the header. You can not mess with that one. Then there is a second sensor right after the first cat. The function of that one is monitoring the functionality of the Primary (first) cat. That one can be easily tricked if you plan to go catless. There is no sensors after the second cat. Therefore you can remove that one if you want and your car won't even notice it. |
#5 | |
1NZ-FE
Yes. You just need to unplug the sensor on the stock exhaust manifold. Take the manifold out and install the header and finally put te sensor back on the header. It should have a bung for the sensor. Pretty simple
Touge Driver
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Do your stock headers look like these from a 1.3 litre Echo?
![]() Or like these from a 1.5 litre Echo? ![]() A guy on Ozecho has swapped the 1.5 litre manifold (the one with the longer primaries) onto his 1.3 litre and is happy with the improvement. Last edited by rob323; 11-11-2008 at 03:52 PM. |
Did you guys just get the 1.3 litre motor, or do you have those type of headers even on the 1.5 litre motors?
The only engine available in the US is the 1NZ-FE (1.5L)
You should be aware that there are some differences on external components between the 1.5L on the first gen Yaris/echo and the second gen yaris. The intake for example is different. The exhaust manifold (header) is very similar between the 2 but there is a slight difference. So a first gen 1.5 yaris/echo header won't fit into a Second gen Yaris unit. If you are looking for a header option for a first gen Yaris/echo, then you should look for the first gen scion xB and xA headers. Those will fit onto a first gen Yaris. |
What I was alluding to was that if the 1.5 Yaris came with a similar longer primary header than the 1.3 litre Yaris (as it did in the Echo), then that may be a cheaper option for the OP to look into instead of an aftermarket one.I have a stack of assorted Echo parts, sadly no Yaris bits though to be able to thoroughly compare them. |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| new 5zigen proracer exhaust 4 yaris | laszlo | Performance Modifications | 13 | 08-16-2007 01:29 PM |
