Parallel Parking Pro
You should be aware that there are pros and cons doing handling mods, as it changes the handling characterics of the car.
In the case of this sway bar, the car can become more tail-happy and could possibly catch you out if you're not careful. Although FF cars tend to understeer on power, they can suffer from lift-off oversteer and pitch you into a corner pointed the wrong way.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#2 | |
Break'em off some.
The TRD bar is not even close to being that stiff. The car will still push at the limit with the TRD bar, lowering springs and stiffer dampers. You would need coilovers with significantly heavier springs to get lift-off oversteer in this car. |
#3 | |
Although you do have a point. I don't have a rear sway bar of any sort, but my lowered springs are stiffer than DF210s, and also an uneven drop, being lowered more in the front, and the car is quite pointy power off, and can kick its tail out when I brake heavily. Just be aware that when you make handling mods, there are benefits but also drawbacks and drivers shouldn't expect the car to be as benign as it is usually set up straight out of the factory.
| TRD sway bar for sedan | punch | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 129 | 09-29-2012 02:04 PM |
| Difference b/w TRD Rear Sway Bar and these? | IsLNdbOi | Performance Modifications | 8 | 11-11-2008 09:13 PM |
| Strut Bar or Sway Bar | blacksan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 04-30-2007 09:31 PM |
| Sway Bar! | dngz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 55 | 01-12-2007 03:31 AM |
| sway bar | Lowfront | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 10-18-2006 08:51 PM |
