![]() Drives: New Join Date: Nov 2008
Need help with Audio, speakers??
Im buying an 07 Hatchback and want to know what size speakers do they come with and how many? I think Im going to replace all OEM speakers and get a good radio. Thank you for your help
![]() ![]() Drives: 2008 blazing blue yaris LB Join Date: Oct 2008
it has 6 1/2 in front and back. you will need a adapter plate to make it fit back into the hole with the right depth.
http://cardomain.com/ride/3151056 ![]() ![]() mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch coming soon: window tint, custom sub grills, tach and........ |
#3 | ||
![]() ![]() Drives: 07 Yaris Hatch 5speed Join Date: Nov 2006
As for making adaptors, just do this. Take out the speaker part of the "Speaker assembly and reuse it. This will save a lot of time. |
i have a ebay store i sell speaker adapter rings that way you dont ruin your speakers. i can cut any size needed. http://stores.ebay.com/MDF-RING-MAST...eNameZl2QQtZkm i always remove the stereo when i sell a car and put it back to original.
#5 | |
Yeah, when I sell my Yaris I might have to get new stock speakers from the wreckers. Also, when I bought mine, they came to the dealer with no deck installed, to encourage the dealer to try to upgrade. So I asked for them to not install the stereo, and got a hood deflector, trunk mat, and rear bumper protector instead. |
#6 | |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
ugh...if you want to save money and mount 6.5"s in the door...cut or pop out the wire mesh of a old 6.5" speaker grill. if you dont have one most stereo install shops have scads of them in their garbage cans.
you can make a spacer ring out of a 6.5" grill if its the right shape, obviously for free. the pro's in doing this is that you would save the factory speaker in case you ever needed to sell the car, and for two, the plastic on the factory speakers is increadibly thin. you would sacrifice mounting stability and sound quality to use them. the way I looked at it, I had a set of $180 components. I spent $10 on a set of spacers. I still think it was worth it.
sounds like it will work as long and its solid and seals up the mounting surface. i recommend using a mdf ring like i sell or buy a plastic ring from a stereo shop.
#10 | |
The Hated One
but yeah, buying one is always the best way...but there are better ways to make a mounting plate for free than to use the 1/8" thick stock plastic speaker housing...
![]() ![]() ![]() Drives: '08 Yaris MM 3d Lb, auto Join Date: Oct 2008
I just ordered 2 pairs of Polk db651's (6 1/2"-6 3/4")for my liftback from Crutchfield for front and back. The salesperson said they won't fit because the tweeter will stick out too far to put the door panel back in place. I've read here before that some make their own rings out of 1/2" or 5/8" mdf board and their speakers fit just fine, different brands though. Has anyone had problems with this? Looking through/at the grill with the stock speakers it looks llike there is plenty of room. Any advice?
Hackers suck! Last edited by rg570lvr; 11-21-2008 at 01:52 AM. |
#12 | |
Thanks for your reply, my Polks just came in yesterday and I can't wait to install them. As I can afford it I plan on changing the hu, from there we'll see. Thanks again.
Hackers suck! |
#14 | |
Hackers suck! |
| Is worth it to replace only front and rear speakers? | tealio | In Car Entertainment + Electronics (audio / video / alarm) | 35 | 04-16-2010 09:11 PM |
| In car Audio - Head Unit installed but a little problem... | YoyotaTaris | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-06-2007 12:34 PM |
| Question for audio experts here... | Terrorize | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 07-04-2007 01:22 AM |
| Component or coaxial speakers? | eflb55 | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 12-11-2006 09:40 PM |
| Matching up right speakers for 4DR Yaris.... ohms match up? | ebowers83 | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 09-13-2006 11:12 PM |
