Old 11-17-2008, 07:48 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
there IS a switch inside the knob that activates the compressor AND THE BUILT IN HEATER...
you do not really want to get beyond that that in messing around the wires...
Old 11-17-2008, 08:28 PM   #2
auxmike
auxmike's Avatar
What about in the deep of winter, will the A/C still kick on?
Old 11-18-2008, 04:09 PM   #3
stran
Drives: '07 Yaris 3D HB Auto
Except the connection to the heater is probably via a mechanical linkage. I know that the vent knob operates via a mechanical linkage. With the car off and there's no power, you can still switch between the vents. On luxury cars I've driven before, the soft buttons activate a little motor that open and closes the damper that only works when the car is on.
stran is offline   Reply With Quote
Old 11-18-2008, 04:21 PM   #4
The knob that changes where the air is blowing does so by cable as you mention. Here are some pictures of what the back of the switch assembly looks like:
From this thread about changing the bulbs:
http://www.yarisworld.com/forums/sho...light=led+dash
If you look at the close-up picture above the outer knob turns a plastic gear. I would bet that there is a boss on the gear that bumps a switch that parallels the AC switch. If so, you could just clip the boss...
Old 11-18-2008, 04:37 PM   #5
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Seeing as you have it all apart anyway can you give us a pic of the cam/boss that activates the air while in defrost mode? dont know why Toyota couldnt have given me the option of defrost with air on or off,like its only a matter of pushing a button if i want the air on.
Old 11-18-2008, 04:46 PM   #6
I haven't actually pulled mine apart. I just remembered seeing the picture of it pulled apart on that thread. Based on the EWD's I think that the "option" is based on whether or not you have the "cold weather package".
Old 11-18-2008, 05:02 PM   #7
stran
I'm in Cali and the cold weather package wasn't an option for me but my defroster is still linked. And thanks for showing me how to subscribe. I can follow the conversation now.
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Do u guys set to Fresh Air for A/C? hans_fh General Yaris / Vitz Discussion 17 06-12-2007 03:24 PM
A/C & Aftermarket intake KSIbucky DIY / Maintenance / Service 2 03-26-2007 09:08 PM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 08:26 AM
