Old 11-18-2008, 03:19 AM   #1
Revsson
Originally Posted by stran View Post
I don't like the way how the A/C has to be on when I turn on the front defrosters. I think there are two ways to fix this: fake out the detector switch so the car doesn't know you turned on the defroster, or kill the circuitry that automatically turns on the A/C.
In case you don't have the Factory Repair Manual Handy:
http://www.etimago.com/yaris/repairmanual/EWD.pdf
http://www.etimago.com/yaris/repairm...nditioning.pdf
This might get a little technical:
Option 1
One guest is that the switch could be inside the control knob itself, and the signal could be turned off by shorting the signal wire or soldering in a resistor. Take a look at page 245 of the Air Conditioning manual for more info about this. Or there could be a switch in the air damper that controls flow to the front defroster. See page 10.
Option 2
The Electrical Wiring Diagram Manual (filename: EWD.pdf) on page 239, 240, and 330 mentions "Defroster Mode Detection SW" in the context of air conditioning. SW means switch. The problem is that I don't know where this switch is physically located in the car. The diagram on page 50 and 52 might help answer this question but I can't put the two together.
Any help is appreciated, and I know I'm not the only person who wants to get rid of this.
It doesn't say it in your profile, but I assume that since you joined in 2007,
that you drive an '07 LB?
Just trying to clarify if there can possibly be any difference in the model
years for the A/C.
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Do u guys set to Fresh Air for A/C? hans_fh General Yaris / Vitz Discussion 17 06-12-2007 03:24 PM
A/C & Aftermarket intake KSIbucky DIY / Maintenance / Service 2 03-26-2007 09:08 PM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 08:26 AM
