![]() ![]() Drives: '07 Yaris 3D HB Auto Join Date: Jul 2007
Except the connection to the heater is probably via a mechanical linkage. I know that the vent knob operates via a mechanical linkage. With the car off and there's no power, you can still switch between the vents. On luxury cars I've driven before, the soft buttons activate a little motor that open and closes the damper that only works when the car is on.
#2 | |
![]() ![]() From this thread about changing the bulbs: http://www.yarisworld.com/forums/sho...light=led+dash If you look at the close-up picture above the outer knob turns a plastic gear. I would bet that there is a boss on the gear that bumps a switch that parallels the AC switch. If so, you could just clip the boss... |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Seeing as you have it all apart anyway can you give us a pic of the cam/boss that activates the air while in defrost mode? dont know why Toyota couldnt have given me the option of defrost with air on or off,like its only a matter of pushing a button if i want the air on.
#4 | |
I'm in Cali and the cold weather package wasn't an option for me but my defroster is still linked. And thanks for showing me how to subscribe. I can follow the conversation now.
| Gas mileage and A/C | Chaad32 | General Yaris / Vitz Discussion | 18 | 01-29-2009 04:31 PM |
| Do u guys set to Fresh Air for A/C? | hans_fh | General Yaris / Vitz Discussion | 17 | 06-12-2007 03:24 PM |
| A/C & Aftermarket intake | KSIbucky | DIY / Maintenance / Service | 2 | 03-26-2007 09:08 PM |
| A/C smelling weird? | Yaris_PR | General Yaris / Vitz Discussion | 11 | 08-04-2006 08:26 AM |
