Old 11-24-2008, 05:24 PM   #1
simonwiley
Drives: 2007 Yaris 2dr HB
yes it does, if you run... say 205/40/17 on the front and 215/35R17 on the back, and for the winter you run 185/XXR15 all the way around, then yes you do need an alignment due to the fact that the difference in tire size will affect your camber/ caster. So it does matter. It may not make enough of a difference in your alignment to be concerned about it, but to be correct it needs an alignment in that situation. Now if you run 205/40R17 all the way around on one set of rims, and 185/60R15 on the other set, then there is absolutly no reason to get an alignment because the tires being a matching set will not affect any of your alignment geometry. You may flame me because I'm the new guy, but I am a ASE Master Tech, and I work as a Senior Mechanic for the State.
simonwiley is offline   Reply With Quote
Alignment settings kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 08-25-2007 08:57 AM
Dealership explains no need for alignment jmjonesey DIY / Maintenance / Service 6 04-23-2007 04:20 PM
Suspension alignment after new springs? mrrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-14-2007 01:05 PM
Wheel Alignment Data Asif Kazani Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-22-2007 12:48 AM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
