![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
It's not a high end audio system. Just use t-taps. As long as the taps are closed tightly with pliers, you're good to go. They're not coming off unless someone physically pulls the t-taps open.
#2 | |
please do not use T taps, please twist/solder these connections. you will also have to run an independent battery signal to the remote start unit. use a wire heavy enough to support the starting process (8GA recommended) |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| remote starter, instaled but cant get tach sig? | karl53913 | DIY / Maintenance / Service | 8 | 11-26-2008 10:40 AM |
| Remote Car Starter | KittenRD | Fuel Economy Forum | 6 | 11-08-2008 11:53 AM |
| starter kill & horn help | spechuy | DIY / Maintenance / Service | 0 | 10-20-2008 01:30 PM |
