Old 11-28-2008, 10:19 AM   #1
so you basically don't have any sort of security built in to the alarms you install? without cutting the ignition wire, all your alarm is is a noise maker.. thief jumps in and drives away because you didn't use an the ignition kill circuit?
My Yaris doesn't have an alarm, but it does have the engine immobilizer, which uses the tansponder key. This is basically the same thing as having an ignition kill switch. The column is still locked without the key as well.
All of these things are easily bypassed by a car theif who knows what he is doing. I don't think that the remote starter makes the car any easier to steal though.
Old 11-28-2008, 10:22 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
if the install is done right, hopping in and driving away will take at least 3-4 minutes instead of just seconds.. removing enough of the ignition wire and relocating the new "tapping point" deep into the firewall means the thief HAS to pull your dash to steal your car..
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
remote starter, instaled but cant get tach sig? karl53913 DIY / Maintenance / Service 8 11-26-2008 10:40 AM
Remote Car Starter KittenRD Fuel Economy Forum 6 11-08-2008 11:53 AM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
