Old 11-28-2008, 08:11 PM   #1
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
Originally Posted by SilverGlow View Post
Why would anyone disconnect A/C to the defroster mechanism?
There is no faster way to remove moisture from the windows and air then using an A/C. If you don't like the coolness, move the temp control to full heat.
This DIY has to be the most idiotic yet! And for what benefit? Surely not for gas savings, as the savings is insignificant....you really need to fill your time doing something useful, productive, and not devoind of logic, and utility.
So how does having bone-dry air on the inside of the car, help remove frost and ice on the outside of the windshield? Glass is a moisture barrier.
This mod is for those that benefit from the added raw heat, including the ceramic heating element, to defrost their windshield. You're confusing defogging the inside (windshield air flow w/ AC on) with defrosting the outside (windshield air flow with maximum heat) in this case.
Also, I can give a real-world example: Security guard watching a landslide area in your own personal vehicle on a cold night. I've done that before, had to huddle inside my vehicle to stay warm some nights, '87 Corolla FX I had until I bought my Yaris. Three quarters of a tank pumping weak heat across the windshield, or a quarter-tank if I dealt with frying my face off instead and used cardboard to redirect the heat up on the windshield. My Jeep I took one night ('87 also, Jeep Comanche w/ 4.0l engine) was the same exact way, quarter tank versus three quarters of a tank idling for 8 hours.
WolfWings is offline   Reply With Quote
Old 11-29-2008, 02:32 AM   #2
stran
Drives: '07 Yaris 3D HB Auto
Out of curiosity, did you unlink the defroster on the Jeep and Corolla? How did you do it?
stran is offline   Reply With Quote
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Help Needed: Unlink A/C to Defroster stran DIY / Maintenance / Service 25 01-09-2009 01:50 PM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
