Old 11-29-2008, 01:21 AM   #1
rg570lvr
Drives: '08 Yaris MM 3d Lb, auto
Originally Posted by rg570lvr View Post
I just ordered 2 pairs of Polk db651's (6 1/2"-6 3/4")for my liftback from Crutchfield for front and back. The salesperson said they won't fit because the tweeter will stick out too far to put the door panel back in place. I've read here before that some make their own rings out of 1/2" or 5/8" mdf board and their speakers fit just fine, different brands though. Has anyone had problems with this? Looking through/at the grill with the stock speakers it looks llike there is plenty of room. Any advice?
I just installed the front pair using the thin rings that Polk Audio provides in the box just like sportin83 said and they fit perfectly. The ring is only maybe 1/4" thick and there is plenty of room for the magnet to clear the window and the tweeter is at least 1 1/2" from the door panel when put back in place. The tip about using the rag to get the retainer ring off of the window crank really works, also a tip I'd like to pass along is NOT to drill out the rivets that hold the factory speakers but use a pair of wire cutting pliers to get behind the rivet head and cut them just like cutting wire. It cuts the rivet head right off, and the rivet slides right out. Way faster and easier than drilling. I have no idea why Crutchfield says these and other 6 1/2" speakers won't fit, I put this off for so long, for nothing. The Polks sound way better than the stock ones, duh. I'll install the rears when I get a chance. Just to clairify something above, I bought the db651 models not the db651s which are shallow models.
Hackers suck!
rg570lvr is offline   Reply With Quote
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 09:11 PM
In car Audio - Head Unit installed but a little problem... YoyotaTaris In Car Entertainment + Electronics (audio / video / alarm) 7 08-06-2007 12:34 PM
Question for audio experts here... Terrorize In Car Entertainment + Electronics (audio / video / alarm) 12 07-04-2007 01:22 AM
Component or coaxial speakers? eflb55 In Car Entertainment + Electronics (audio / video / alarm) 12 12-11-2006 09:40 PM
Matching up right speakers for 4DR Yaris.... ohms match up? ebowers83 In Car Entertainment + Electronics (audio / video / alarm) 7 09-13-2006 11:12 PM
