Old 12-06-2008, 09:33 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
the only problem with custom is that they rust alot faster due to bends and welds.. i guess as long as you dont get salt during winter youll be fine..
Old 12-06-2008, 11:02 AM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
A $3 can of high heat paint in the color of your choice fixes that.
Most exhaust shops use alumnized tubing, so the only thing that will rust are the welds.
Old 12-08-2008, 02:22 PM   #3
justjesus
justjesus's Avatar
Drives: 2008 Liftback
True that. I just helped a buddy out with his Evo X. The shop used aluminized tubing, and about two weeks later we pulled it off to paint it (for him, it was about looks). The welding was showing some surface rust, but the tubing was looking okay. Some prep work, a couple of cans of high temp in flat black, and it looks pretty good.
at3GG / Racerfreak: You can do like this guy. No need to hack up your stock exhaust. He had an entire exhaust made up. He needed to take it to the dealership for reflash, so he swapped the stock exhaust back in. Didn't take long either
racerfreak Regarding the 2.25"/2.5" in/out, i thought maybe Flowmaster had one, but a quick search through their 40 series and 60 series didn't show one. It seems the only time I see different sizing in/out is when it's a dual outlet design.
Old 12-10-2008, 11:14 AM   #4
marcus
toyota
marcus's Avatar
sorry that didnt work either only because rust also will come from the inside weld of the pipe...
Old 12-10-2008, 12:44 PM   #5
largeorangefont
Break'em off some.
True, but it will take many many years for it to be a problem if you protect the outside of the pipe.
You could send it off to be thermal coated if you are really worried about it.
Old 12-06-2008, 01:16 PM   #6
buy stainless piping...
http://www.exhaustdirect.com/
likely where ill buy my piping and bends...unless i find a shop that can do mandrel bends themselves...
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 04:05 AM
Rusty Muffler dadi_oh Cosmetic Modifications (Exterior/Interior) 7 07-03-2009 08:45 PM
Custom Cat-Back exhaust Yaris TS CASTREX Yaris TS Talk 16 10-24-2008 12:56 PM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 10:36 AM
