Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
TRD Springs issue
I just installed my TRD lowering springs, and cut the bumpstop by 1" (the lower portion), and everything went together smoothly, but I'm getting a bit of rub on the drivers side under somewhat-hard cornering (<20mph). I have 215-40-17" on a 40mm offset, which is pretty standard on these, and everyone said there would be no rub, so I'm a bit surprised. Is this a bad spring, or an issue that will resolve when the alignment is corrected?
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
Lose some weight. jk
Your tires are a bit too wide and offset a bit too low. Need to trim the plastic fender liner and use a heat gun to push back the plastic liner a bit. If that doesn't help, get some camber bolts and add a little bit of negative camber up front |
#3 | |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
I have to agree with the others
Your tires are a bit too wide and offset a bit too low... your going to rub
Just call me Ray, better?
im not gonna say what every one else says.... damnit their right... what they said
Super Newbie
You can avoid that gap after trimming by heating up the liner with a heat gun and pushing the bulge in the liner back so that it kind of "curves" with the curvature of the fender. Theres only a slight gap and keeps out most of the road debris from getting in. Just don't trim too much of the fender liner.
Interesting. OK. Will the Tanabee NF210's be the same issue? Can I do anything spacer-wise to the springs (top or bottom) that might give me that slight height-increase to eliminate rubbing on all-but-the-most-extreme cornering? Or am I going to have to live w/ stock springs? I'm not cutting my fender liners, so its make these springs work, buy something that will work, or live with stock.
AS a second thought, would adjustable shocks with the stock springs allow me to drop it a bit, kinda splitting the difference?
Also, how do people work-out the TRD springs w/ TRD 18's w/o rubbing? I can't imagine Toyota selling anything at the dealer that would result in a rub at relatively low speed and moderate cornering (I'm only 160 lbs, so that can't be it! :) |
Super Newbie
You don't want to do the most simplest modification because of? But you would rather go through the trouble of putting your stocks back on and losing out money selling your springs? or even buying spacers or trading for other springs?
If you still have that left over 1" piece of bumpstop you cut off, put it back in and see if it helps. Or you can just keep rubbing on that fender liner until the noise goes away. The plastic will eventually wear off. |
#10 | |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
His wheels are too wide that's all.
#12 | ||
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
The springs come with a sheet on what the camber should be and such. I'm using 205/40/17 and I too have this problem with the +40. Once spring comes, I'm adjusting them to spec. Quote:
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
On the TRD spring and shock package there is nothing in the install instructions for cutting the bump stops. As you indicated, going from Tanabe to TRD, with the Tanabe's I am pretty sure the stops were cut per their instructions for install, with the TRD's they don't. Did mine myself and didn't cut them. I think new bump stops is the start to your solution.
#14 |
~ ambient one ~
I'll do that for mine then, but again I'm gonna ask Toyota while ordering them. It doesn't bother me much since I got used to it.
Now the person who created this thread, are you running on stock shocks still?
AMBIENTLIFESTYLE
#15 |
Yes, stock shocks at this point.
Regarding the comment about why I wouldn't want to cut my fender liners, its because I don't do mods to my car that will fundamentally change the original vehicle's integrity. I also understand that the fender liner is there for a reason, so i want to keep it there. I'm not averse to spending a small amount of money relative to the cost of the car to do the job right. To me, cutting the fender liner or allowing it to continue to rub is not the "right" way. If it can't be configured correctly, then I don't need a drop. Thanks for all the input. I'll try installing the original bumpstops ( I cut a junkyard set, not the originals.) After that, it sounds like I need to investigate TRD shocks/struts. |
#16 |
I had the same issue and the main problem is my wheels are too wide. I got them off a website and I got sold the wrong offset. When the TRD springs were installed I also cut the bumpstops.
To fix the issue, I installed spring rubbers. You can get them at racing supply stores. They are used in NASCAR to tighten or loosen a cars suspension. I put 1/2" spring rubbers both front and back, and it solved my rubbing issue, AND stiffened the suspension when cornering. They can be found on Ebay also very cheaply. I think I paid $40/set.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
#17 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Crazzy= anything wider than 165mm is too big for this car Even 15's too big. Why do you want to track on one side of tyre? The tyre just tips to one side in cornering? just for looks I guess its is with you guys. Buy a used Porsche or Nismo or Evo. Race yaris HeHe!
#18 |
Had similar issues a year or so ago. I was running 215/40/17 with a +40mm offse and the rear rubbed and not the front. The shocks should not play a role in it.
| tanabe nf210 vs. TRD lowering springs?? | static808 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 37 | 01-23-2012 11:00 PM |
| Are my trd springs installed upside down? | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 11-17-2008 11:12 PM |
| Question about 2 kinds of TRD springs & rear strut bar | Astroman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-18-2007 05:44 PM |
| NF210 versus TRD springs | nurburgring | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 04-01-2007 04:30 PM |
| HOLEY COW 674.75 to install TRD lowering springs | dbaxter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 08-09-2006 12:40 PM |
