Old 12-07-2008, 01:10 PM   #2
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Put your seats back in and remove the rear speakers ( in the rear deck)... that will give enough breathing room for the bass to enter the cabin, and still allow you to have your back seats in the car.
2nd... In terms of clean bass... its always better to go with 2 subs and stress them less (less cone movement) than have one and force it to move a lot. This is so because of mechanical noise, as well as BL (magnetic force) non-linearities.
Sealed boxes give a near perfect in car frequency response, however, ported boxes if designed properly can do the same exact thing, except with much less cone excursion (cone movement)... but at the huge cost of box size.
So, realistically, I see you having two options.... 1 sub ported, or two subs in sealed boxes.... amp power doesn't really matter, the more power you give a sub the more distortion it creates, but the louder it gets (to a point).
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Super Amazing Oil Change DIY id3379 DIY / Maintenance / Service 34 11-28-2008 01:20 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
