Old 12-09-2008, 02:24 AM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Originally Posted by IllusionX View Post
i belive the yaris uses separate grounds and a common positive.
yeah thats right my bad. ground in diagram is actually a common positive.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 12-09-2008, 09:10 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by tkevin07 View Post
it should be one common ground and two positives, does the low beam have power when the high beams are on? need to rewire a HID kit, telescopic =D
The yaris uses constant positive everywhere.. and a switched ground. You can basically tap into any wires in the car if you are lazy to add a fuse for whatever you are doing. And then use the ground point of your choice....
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
F.S. MOMO Acropolis Evo Carbon Kevlar Competition Seat with 4 piont Harness Ric n Sov's Vitz RS Items for Sale by private party 2 10-19-2008 01:34 AM
Headlights harness slvryaris Cosmetic Modifications (Exterior/Interior) 13 07-19-2007 12:19 AM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 04:19 AM
