The clutch is hydraulic, so no cable... The belt doesn't have an automatic tensioner, instead the alternator pivots forward on a bracket to take up the slack. And belts don't go bad in 10,000 miles but usually stretch just a bit and NEED tensioning. But your a mechanic, so you already knew all this...
![]() As for the clutch squeek. Tacomas have had this issue for years. The remedy is a shot of PB blaster on the slave cylinder rod every oil change. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
| Toyota Maintenance at Dealership? | fmicle | DIY / Maintenance / Service | 18 | 03-17-2012 11:27 AM |
| 5K maintenance | Mikeb Yaris | General Yaris / Vitz Discussion | 18 | 12-05-2008 02:05 PM |
| Question about required maintenance | gm830 | DIY / Maintenance / Service | 9 | 11-04-2008 03:14 PM |
| how much does the first maintenance service cost | hans_fh | DIY / Maintenance / Service | 25 | 07-05-2007 10:01 AM |
| Do I need to hava a 1000-mile maintenance service?? | hans_fh | DIY / Maintenance / Service | 3 | 11-24-2006 06:13 AM |
